It is currently Fri Feb 27, 2015 2:52 pm
 Post subject: Help with plan for gaming PC for build in August
PostPosted: Fri Apr 05, 2013 1:04 pm
This is my proposed set up:
ASUS F2A85-V PRO ATX AMD Motherboard
CORSAIR Enthusiast Series TX650 V2 650W High Performance Power Supply
G.SKILL Sniper Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1866 (PC3 14900) Desktop Memory
Intel Core i7-3770K 3.5GHz (3.9GHz Turbo) LGA 1155 Quad-Core Desktop Processor
Seagate Barracuda 1TB 3.5" SATA 6.0Gb/s Internal Hard Drive -Bare Drive
COOLER MASTER HAF 932 Advanced RC-932-KKN5-GP Steel Computer Case
either
EVGA SuperClocked GeForce GTX 660 02G-P4-2662-KR Video Card
or
MSI N660Ti PE 2GD5/OC GeForce GTX 660 Ti 2GB 192-bit GDDR5 PCI Express 3.0 x16 HDCP Ready SLI Support Video Card
moreover:
should I plan on getting the new Intel chipset that is releasing this summer?
Give in mind that I use photo shop and other programs to edit movies and photos.
Games that is of focus is Hawken so looking to stay with an Nvidia card
Plan on making bootable drive a 128Gb ocz ssd
already have 2 monitors, mouse
any thing i forgot to mention that would you better your recommendation let me know
Thank you in advance
 Post subject: Re: Help with plan for gaming PC for build in August
PostPosted: Fri Apr 05, 2013 7:26 pm
You have mismatched mobo/CPU. You need an Intel Mobo for the Intel CPU. A z77 socket motherboard can be used with the core i7. You might want to play around with builds on pcpartpicker.com. They have a compability checker to make sure everything fits.
LatiosXT will probably be around later with a better build. Time for me to hit the bed.
PostPosted: Fri Apr 05, 2013 7:51 pm
I never suggest builds... Well, usually :P If it's in August, I believe Intel's Haswell chips are out by then. If you need to plan something now... A Core i5-3750K and a Z77 board should do.
PostPosted: Sat Apr 06, 2013 6:14 pm
thanks for the help, this is my first build and just started really putting thought into in but clearly havent paid to much attention to detail, but yea this is for a build in august
PostPosted: Wed Apr 10, 2013 5:45 am
Check out the new hardware and mobo setup for the i7s. You've got a new bridge, no front side bus (much better!), and your RAM is now triple-bridged, which means you need 3 sticks of ram (3x 2gb or 3x 4gb), no more (4 sticks hurts your throughput), no less (2 sticks hurts your throughput), if you're looking at min/max. Many build websites don't seem to account for the triple-bridge, it's a new chipset feature. You'll of course want your maxed out 555mb/sec r/w 128gb ssd to boot your game maps as getting in early means getting a better tactical position (hawken). You can keep your OS (I prefer Win8pro) on a nice 1TB drive with 64mb cache and just stick your cached files on the ssd, there are notes about how to improve your OS speed without sticking all of your bloatware on the precious real estate.
pickup your 690 or TITAN card and go crazy trying to find a game you can't play on max, although by then maybe BF4 will be out...
