It is currently Tue Apr 28, 2015 1:08 pm
 Post subject: Laptop cooling
PostPosted: Sat Mar 30, 2013 10:25 pm
I'm using a Asus aluminum lap top corei3 windows 7 500gig hardrive computer. I recently downloaded speccy from piriform (ccleaner site) and noticed at times my temps are around 50-53 degrees C. Seems warm to me so I sat the laptop up on one of the rulers that look like a triangle from the side to elevate it.
Is there better cooling devices for this and what should the temp be around?
 Post subject: Re: Laptop cooling
PostPosted: Sun Mar 31, 2013 12:53 pm
Laptop parts are typically designed to withstand higher heat, and for Intel's chips, usually that's in the 100C-110C mark. Same with the GPU. You could get a laptop cooler, but don't expect it to shave off any more than a few degrees.
PostPosted: Mon Apr 01, 2013 9:51 pm
You can purchase from Amazon after reading customer reviews
PostPosted: Sun Apr 14, 2013 2:46 am
just make sure your laptop is elevated so air can circulate in it.
value point distribution
