It is currently Tue Apr 28, 2015 4:41 am
 Post subject: Looking for a good Web Host
PostPosted: Fri Mar 29, 2013 4:10 pm
I've been with 1&1 for years, and they have worked well enough for me, but I'm wondering if I can get something better for my money. My website is small, and I'm more concerned about finding a host with a decent webmail client (1&1's webmail sucks). I've seen a few host pop up in multiple top ten lists - JustHost, inMotion, BlueHost, HostGator, etc. - but I wanted to get some actual user opinions before putting any money down. Right now I am leaning toward JustHost or iPage because of their low prices. If you've worked with these or any other host please let me know what you've though of them. I would be grateful for any recommendations from the MPC community.
 Post subject: Re: Looking for a good Web Host
PostPosted: Sat Mar 30, 2013 10:24 pm
Monkey Federation (Top 10)
I'm also with 1&1 and I found that using mail forwarding solved my problem. I have it forward all my web mail to hotmail. Your could just as easy forward it all to gmail or the like. I agree there web mail site is fairly poor but forwarding works good.
PostPosted: Thu Jan 30, 2014 2:54 am
Mine is gigapros.com
They are cheap and excellent support 24/7. You get answer in less than an hour.
If you are not server administrator, I recommend you to focus on the support.
PostPosted: Sun Mar 30, 2014 10:52 pm
Look for user concurrency. They almost always try to mislead. So press them.
