It is currently Mon Apr 27, 2015 5:05 pm
 Post subject: M11x AlienFX Issue
PostPosted: Fri Mar 22, 2013 9:01 pm
Hi! So I bought "Ravaged" for $5 on a STEAM sale and I finished downloading it, installed it, then it started. DUH! That's normal! Thing is my alienFX shuts off when it starts and random FX areas flash then it goes to only the bottom right vent FX light being on, then I tried turning off AlienFX and turning it back on, didn't help, it stayed on in the same spot either way, so I ended up leaving it at the off state (unknowingly) and exited. Then my lights stayed the same, so I tried enabling it again and it went fine (right back to all red). Started the game again and same thing, only the first time it was blue color and this time it was white so I set my video options and exited, oh and before I exited I noticed the ALIENWARE logo at the bottom of the display turned on white as well. After I exited it went back to normal. Very weird as this hasn't happened with my 100+ other STEAM and Origin games. Thanks! :)
My laptop is a Alienware M11x R3 i5
 Post subject: Re: M11x AlienFX Issue
PostPosted: Wed Mar 27, 2013 4:30 am
Could be a corrupt download.
Delete the game and try downloading it again.
PostPosted: Thu Mar 28, 2013 10:56 pm
OK...Turns out, Its just a game issue! I started a online match and it started changing colors, If I was the blue team the keyboard was blue, and the same if I was red. It would switch to all white after the team selection though and would flash red if I took damage. So it's all fine! Thanks for the help!
