It is currently Fri Jan 30, 2015 12:56 am
 Post subject: Are these parts compatible?
PostPosted: Fri Mar 08, 2013 12:27 am
Cpu: AMD FX-4300 Vishera 3.8GHz (4.0GHz) Socket AM3+ 95W Quad-Core Desktop Processor
Motherboard:ASUS M5A99FX PRO R2.0 AM3+ AMD 990FX SATA 6Gb/s USB 3.0 ATX AMD
Keyboard : Lenovo Ideapad Z565 Keyboard
Memory:G.SKILL Ares Series 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 1866 (PC3 14900) Desktop Memory Model F3-1866C10D-16GAB
Graphics: MSI N630GT-MD4GD3 GeForce GT 630 4GB 128-bit DDR3 PCI Express 2.0 x16 HDCP Ready Video Card
Hard Drive: Seagate Barracuda ST31000524AS 1TB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Disc Drive: LG Black 14X BD-R 2X BD-RE 16X DVD+R 5X DVD-RAM 12X BD-ROM 4MB Cache SATA BDXL Blu-ray Burner, Bare Drive, 3D Play Back (WH14NS40) ... - OEM
Btw this is my first build so if you have recomendations please tell me and my budget is 850$ thanks
Lenovo Keyboard Cover
 Post subject: Re: Are these parts compatible?
PostPosted: Fri Mar 08, 2013 1:08 am
I didn't read a single word. The answer is yes. Round peg, round hole.
I'm not saying that any of that is sane because you seem to have your mind set and you'll buy what you want no matter what. If you posted this in the correct section (help me build/buy), I'd call you fucking nuts. I can give you the same performance with many other suggestions. Mind you, it won't be AMD stuff and current. Intel kind of did this more than 4 years ago, you don't need 16G memory, you have no SSD...and just picking parts randomly.
It's a correct placement if you want me to blow up on you with deep discussions. You're way off if you want me to help with build/buy because that's another section; it's hard to miss. I think you have a deepthroat build. It's more than "stinks" and swallows the entire thing without asking. You need 16G of memory like you need a hole in the head.
You're biased and an Intel i3 would be more than fine, iGPU and all. An HD4000 iGPU would be better than a discrete GTS 630 and you also get an actual CPU to do work. This place is about technical discussions on hardware and we have a section all about building and planning.
There's 10 types of people that understand this: The 1's that do and the 0's that don't.
PostPosted: Sat Mar 09, 2013 10:24 am
hi chumly
I agreed with you.
PostPosted: Sat Mar 09, 2013 7:24 pm
Million Club - 20 Plus
Good thing you went easy on him.
PostPosted: Mon Mar 25, 2013 4:39 am
While AMD does have some decent options, I wouldn't say that FX4300 is one of them. the FX6300 is barely any more, and packs a lot more power. Priced to compete against the i3, it actually does favorably.
fx4300- 3.8-4.0GHz, 2x2MB L2, 4MB L3
fx6300- 3.5-4.1GHz, 3x2MB L2, 8MB L3
If you can't spare the $20 difference, cut the motherboard down from 990FX, to a 970.
That video card wont do much. I don't know the purpose of this build, so should I assume, gaming isn't a priority given that video card?
If it IS - a 650 is much more powerful.
http://www.newegg.com/Product/Product.a ... 6814127703
That one is $100 and has a $20 rebate.
For the memory - if you get the newegg deal of 15% off, making it $93.50 then great. If not, don't worry about 1866MHz memory. 1600MHz is fine, especially when you're not spending for performance CPU/GPU.
What's the point of that keyboard? Start your build questions with a purpose so others can tailor recommendations to your needs.
