It is currently Fri Mar 06, 2015 6:13 pm
 Post subject: Help! Monitor Flashes Black Randomly on New Build.
PostPosted: Sun Mar 24, 2013 2:08 pm
This is my friends PC that he just got done building and I'm not too familiar with APU builds, but I'm sure I downloaded the right drivers for it from AMD's site, I even downloaded their "Auto-Detect" tool and it says drivers are up to date.
CPU:
http://www.newegg.com/Product/Product.a ... 6819113282
MoBo:
http://www.newegg.com/Product/Product.a ... 6813157334
Win 7 x64
Everything is working perfectly, but the monitor flashes to black for just one or two seconds and it's fine for a while...it's random, sometimes it won't flash for an hour or so, sometimes it does it every 15secs. Monitor works fine on his other PC.
The monitor is hooked up through VGA, I don't have a DVI converter to try that port, but his HDTV doesn't flash black at all when he hooks that up through HDMI...
Any help on the matter?
Let me know if you need more info.
Thanks!
 Post subject: Re: Help! Monitor Flashes Black Randomly on New Build.
PostPosted: Sun Mar 24, 2013 3:31 pm
well if it works on another computer I would say its a vcard problem.
PostPosted: Sun Mar 24, 2013 3:41 pm
There is no video card, it's just the MoBo and APU/CPU.
