It is currently Mon May 04, 2015 5:25 am
 Post subject: Would like a little advice on a build
PostPosted: Sat Mar 09, 2013 3:06 pm
https://secure.newegg.com/WishList/MySavedWishDetail.aspx?ID=21875312
Hello, I'm looking for some help with this build. Can I get any suggestions?
I already own the a computer case, a power supply (http://www.newegg.com/Product/Product.a ... 6817182273) (not sure if I screwed up on this or not!), OS, and blu-ray drive, so I believe this is all that remains. I'm just wondering if I'm bottlenecking myself at any point, or buying one part that's too expensive/good for the rest of the build. I would prefer if it would get below ~900.
I'm just using this for gaming, thanks.
 Post subject: Re: Would like a little advice on a build
PostPosted: Sat Mar 09, 2013 3:55 pm
Mr. Late Night
Mr. Late Night
Well, I'd make some recommendations but your wishlist doesn't seem to be public at least it keeps bringing up that the wishlist is empty. It might also help once that issue is fixed to know what the planned uses for this build are.
PostPosted: Sat Mar 09, 2013 10:26 pm
It should be fixed now, let me know if it stills errors. Thanks.
I'll just mostly be using it for gaming, normal/high end, just want to get pretty decent performance.
PostPosted: Sat Mar 09, 2013 10:34 pm
Mr. Late Night
Mr. Late Night
Nope, still comes up empty. Would be a quicker reference as well if at all possible for you to list the parts individually.
