It is currently Sat Apr 25, 2015 8:01 pm
 Post subject: (Legacy) Printing From a Smart Phone?
PostPosted: Sun Mar 03, 2013 12:03 am
Location: Playing Chicken with the Train at the River. Party Time!!
I Googled for reviews of Smart Phone Apps that support legacy printers (no wifi support) and stumbled across an app called Cloud Print. I installed it and it works as advertised.
My question is: Have any of you installed an app to print from your smart phone and what app would you recommend?
P.C. – Windows XP SP3
Phone – Google/Android/Samsung GS3
Price? Prefer free but all options will be appreciated.
 Post subject: Re: (Legacy) Printing From a Smart Phone?
PostPosted: Mon Mar 04, 2013 8:29 am
Legacy printers are ones without Wi-Fi? I thought you meant printers that use the LPT port. I usually have no need to print something out of my phone, mostly because I don't print much anyway.
But just to humor you, I did find this http://www.labnol.org/internet/print-fr ... nes/17827/
PostPosted: Tue Mar 05, 2013 6:20 pm
LOL… You are correct… I should have tempered my post as a comparison of today’s technology!
Thanks for posting the link! However, that link affirms the use of ‘Cloud Print’:
Link wrote:
Update: You can also use Google Cloud Print for remote printing
It appears that 'Cloud Print' may be an acceptable option!
Thanks for your help! :D
