It is currently Sun Feb 01, 2015 6:38 pm
 Post subject: XFX Fire & Ice
PostPosted: Tue Feb 19, 2013 8:15 pm
Well I had a little time between Lan parties and Builds ( still waiting for one to come back) I I had this concept before in 2009 and after a few complete ice mods I was ready to attempt to build it. The build will be called Fire & Ice, making the case from liquid resin and trying to use a least amount of metal possible with a waterfall reservoir.
I purchased the ECS model P67H2-A2 Deluxe
I like to thank my sponsors for supporting my projects over the years.
A have a long way to go and a short time frame, Do you think i can make it?
 Post subject: Re: ECS Modmen Case Mod Entry Fire & Ice
PostPosted: Tue Feb 19, 2013 8:42 pm
First thing is getting my layout on The board that i will be using for my mold and double checking measurements.
adding 2 by 4 and attaching them with screws from the back
getting a 3d visual in my mind ,
Side view of the side panel
Molds are ready
Am I making cookies or a case mod you decide
Ready to Pour
make sure you add you Mold release
Sorry for the blur i was probley dizzy from the fumes
Mixing the resin with the catalyst
I let it set over the next 24 hours
Ok need to keep pushing on this if i am going to get done
Vote every day till the end for your favorite
http://www.ecsmodmen.com/
PostPosted: Wed Feb 20, 2013 8:58 pm
After letting the resin harded for about 2days here is the end result
One cool side panel
all cleaned up
getting a good idea on attaching the fans
front panel fan placement
rounting the front & side panels for Plex glass Insert
Side panel sanding from 50 , 150, 400 , 1000 grit.
More plexi has arrived to finish my newest feature to the case.
PostPosted: Mon Feb 25, 2013 9:04 pm
Dont forget to go and vote!!!! 2 1/2 days left. http://www.ecsmodmen.com/ I am pushing hard to finish it.
Adding the case fans!!!
I wanted to do something different and cut them out myself instead of using the large hole cutter.
trusting old craftmans scroll saw
Setting the blade through the pre drill holes
A little etching action
testing the LEPA fans
and the other side again cutting out the fan holes
Thanks again for taking a look.
PostPosted: Thu Feb 28, 2013 7:26 pm
More ecthing work. If you like the build , Dont forget to vote , Voting ends 3/5
(Spolier alert) http://www.ecsmodmen.com/entries/5123j26QWE95
Can any body quess why i did the wording on 2 different sheets?
every body need a little fire dragon
Start my second very time consuming project with the plexi & weld on #4
Probley a day between each pic
this is all cut by a table saw and sandpaper , no lazer here
a little water test for my first ever Custom reservoir
thank you for subbing and following along 5
voting page (Spolier alert) http://www.ecsmodmen.com/entries/5123j26QWE95
PostPosted: Fri Mar 01, 2013 10:30 pm
Started working on the Floating tier for the MB. Thank you old trusting Intel for making a perfect template for Drilling holes for Standoffs
TAP, TAp, TAp
Found some arcylic Rods and wanted to incoportae them into the Build
Getting a idea on how its going to look
A last minute decision to make my own case feet
Mounted to the base
I am going to leave you with a teaser Pic
PostPosted: Mon Mar 04, 2013 3:20 pm
Small update,
using a small bit of clear epoxy to secure the sides to each other and base.
adding a hinge back panel
Installing hardware
water testing
Preview update coming later tonight.
PostPosted: Mon Mar 04, 2013 7:59 pm
Preview update
16 hours left in the voting for the ecs Modmen comptetion , Please go vote!!!!
Here is a little preview of Fire and Ice
http://youtu.be/_gG69oMNptY
A big thank you to all the sponsors involved in the project, Intel, LEPA, ADATA & Seasonic, & ecs for hosting a amaizing contest.
More to come, !!! sleeving and better lighting !!!
PostPosted: Tue Apr 02, 2013 5:16 pm
Who won? You build is pretty cool.
PostPosted: Fri Oct 25, 2013 4:57 pm
It was a long a Fun Summer, Lot of exciting stuff for ICE Mod. I took it to Quakecon & a few Midwest Lans. Had over 5 interviews Quakecon and a ton of pics taken and in a article on CNN.
Adata Up their Game again and sent Some amazing memory. they are also making the memory with a Black PCB board
http://www.newegg.com/Product/Product.a ... 6820211752
Here are just a few of the pictures of the ram and the adventures
Thank you for looking another update soon
PostPosted: Mon Nov 18, 2013 1:46 pm
A big thank you to XFX for sponsoring a R7970 and a pro 1000 watt PS for the final tour of the Ic pc, it was at LAN OC, Indiana Tech, FW Makers fair, IU Lan and of course setup as a Demo Station at FortLAN !!!
Thank you for Checking it out, I have 2 more projects coming up
