It is currently Tue Apr 21, 2015 8:04 pm
 Post subject: Is there any way to get my data back?
PostPosted: Mon Feb 25, 2013 7:20 pm
tldr:
os is vista business
task manager was used to shut down explorer, which for some reason did not automatically restart
began getting an 'i/o error; disk access failure' message from peerblock, which is installed onto c drive
attempted to save a file in notepad++, seemed successful so i saved all of my work, some on c and some on an external hdd.
upon reboot, vista installed an update
all of the files i had saved after explorer was killed became zer0 size files, even the ones on the external hdd ... only the files i had saved were affected
could not find the original files using a file system check, easus data recovery or recuva.
HELP!!!
i'm not sure exactly what happened ...
the last time i used my pc, explorer was acting really slowly, so i called up the task manager and shut down explorer, expecting vista to restart it automatically ... oddly, that did not happen. following that, peerblock began intermittently giving some message about an 'i/o error; disk access failure', which is troubling because it is installed onto c drive ... i started panicking because i'd typed up quite a bit that i hadn't saved and, fearing the worst, i attempted to save a new file in notepad++. it seemed sucessful, so i then continued to save all of my work in progress and rebooted.
upon reboot, vista immediately began installing an update. when that finished, i attempted to resume my work and found that all of the files i had just saved had been overwritten into zero size files. some of these files represented more than a year's worth of work.
a file system check did not restore the files, so i tried easus data recovery and recuva and found that neither were able to locate the previous versions of these files.
is there any program or tool that can restore the files i just lost?
EDIT: hd tune reports 0.0% damaged blocks
 Post subject: Re: Is there any way to get my data back?
PostPosted: Tue Feb 26, 2013 5:50 am
Sounds like you lost your partition structure. Use TestDisk either via Windows or safer still would be to boot off a usb drive. You can quickly use Rufus for that. TestDisk is simple, straightforward yet incredibly powerful. It will find and allow you copy/save your data over to a safe drive. Then make sure you scan for virus and malware, odds are you're infected.
BTW, I know this is your first post and all...and I do welcome you to the Forums, but Awwk! Capitalization exists for a reason! It's a tool, don't be one, so use it and make your Mom proud and don't appear IQ deficient. Capitalization is the difference between helping your uncle jack off a horse and helping your Uncle Jack off a horse.
Users browsing this forum: No registered users and 13 guests
