It is currently Sat May 18, 2013 10:58 pm
 Post subject: Remote Desktop
PostPosted: Wed Feb 20, 2013 4:51 am
Hey guys. I was curious if there were any alternatives to the remote desktop feature in Home Server 2011. I let the SSL Certificate expire and I don't want to renew it unless its absolutely necessary because I am moving soon and need every penny. I use the remote desktop feature in home server 2011 to remote into my home PC so I don't have to use my work network. For the past 4 years over two versions of home server, this has worked extremely well for me. To be honest its pretty damn fast too. I can't use go to my PC because it requires permission from the network admin and is blocked otherwise and I doubt that permission will be granted. So here I am, I thought if anyone would know, its you guys here.
Thanks in advance.
 Post subject: Re: Remote Desktop
PostPosted: Wed Feb 20, 2013 5:43 am
I should probably give you more information, I apologize for not doing so. Last Sunday we had a minor surge they blew up my 5 year old Lynksys router so to replace that I bought a Netgear WNDR4300. So far so good with that. Its fast and my wife is happy because the wireless is back and trust me, if any of you are married having your wife happy makes things so much easier. However, having just gotten this last night I can't find where you open up the ports for the necessary apps to work properly. The page works and I can log in however when I click on an available PC I get an error. I tried to attach a screenshot but it wouldn't upload. So the jist of it is "Your computer can't connect to the remote computer because the Remote Desktop Gateway server is temporarily unavailable".
Thanks again.
PostPosted: Wed Feb 20, 2013 7:15 am
Monkey Federation (Top 10)
http://portforward.com/
PostPosted: Wed Feb 20, 2013 8:34 am
Thanks for this. I don't see my router in the DB but they have the step up from mine. I'll post back and tell you how I make out.
PostPosted: Thu Feb 21, 2013 4:20 am
use DDNS, all router has that configuration.
http://dnslookup.me/dynamic-dns/
PostPosted: Fri Feb 22, 2013 4:46 am
This still doesn't work. I messed around with it the other night and opened the correct port 3389 but still, gateway server not available. I remember that I had other ports opened as well on my old router but I can't remember what they were. I'll check out DDNS. The fact that the page is up and says that the PC is available for connection is a good sign to me.
PostPosted: Fri Feb 22, 2013 5:10 am
https://www.grc.com/x/ne.dll?bh0bkyd2
Do a scan using ShieldsUP and see if the ports are actually open or being blocked by your ISP
PostPosted: Fri Feb 22, 2013 5:43 am
Good idea. Thanks for that. I'll try that when I get home.
PostPosted: Wed Feb 27, 2013 4:11 am
Hey folks. I haven't forgotten about this. I looked on WHS site and they mentioned that 443 and 4125 need to be opened up as well 3389. I have the ports opened but I can't assign them to the correct protocol because it simply isn't an option in the drop down. The admin menu is very limited with this router. That wasn't the case with the Lynksys wrt150n. I don't know what to do with that but I suppose I could try Tomato firmware which is mentioned in the small hand book I got for the router. I am going to keep trying on this because I would rather use my home PC for internet access then be monitored here at work. Not that I am looking at anything bad, Yahoo Finance and Sharebuilder, GMail.
Anyway, thanks for the help.
PostPosted: Wed Feb 27, 2013 4:12 am
I did this, the port is open.
PostPosted: Thu Feb 28, 2013 4:09 am
Hey guys, I just wanted to let you know that I can get into the server now but I still can't get into the main PC. So that's progress I suppose.
http://filedump.org/files/chL4t1362055696.html
