It is currently Sun May 26, 2013 1:30 am
 Post subject: need help on my c program
PostPosted: Wed Jan 30, 2013 5:28 pm
I wrote a program to find the volume of a cube but I don't know why i'm getting error?
#include <stdio.h>
int main(void)
int h;
int w;
int l;
int a;
int v;
Printf("Please type in the legnth: ");
Scanf("%d ", &l);
Printf("Please type in the width:");
scanf("%d ", &w);
Printf("Please type in the height:");
scanf("%d ",&h);
a = h * w;
v = a * l;
printf( The volume of cube is %d ", v );
return 0;
I would apperciate if you could help me and explain what i did wrong. Thanks.
 Post subject: Re: need help on my c program
PostPosted: Wed Jan 30, 2013 5:33 pm
If that's your code verbatim...
  • You have capitals in some of your scanf and printf calls
  • You're missing a " in the last printf call.
Otherwise it runs just fine.
PostPosted: Wed Jan 30, 2013 6:23 pm
Thanks latios. Did everything you told me and it worked. But what I don't get is why do I have to type in length twice? I don't see anything in the code that show's why I have to.
PostPosted: Wed Jan 30, 2013 8:14 pm
I ran this through gcc, no problems encountered.
PostPosted: Wed Jan 30, 2013 10:33 pm
As you can see from the picture i had to type length twice. Which is weird. I'll try to compile it again. I'm using microsoft's developer command prompt to compile it.
PostPosted: Wed Jan 30, 2013 10:35 pm
revised code:
#include <stdio.h>
int main(void)
int h;
int w;
int l;
int a;
int v;
printf("Please type in the legnth:");
scanf("%d ", &l);
printf("Please type in the width:");
scanf("%d ", &w);
printf("Please type in the height:");
scanf("%d ",&h);
a = h * w;
v = a * l;
printf( "The volume of cube is %d ", v );
return 0;
PostPosted: Wed Jan 30, 2013 11:34 pm
Part of me wants to say if you're semi-serious about this, you should install a VM like VirtualBox and get a Linux distro up and running. Mostly because many development environments use gcc, so it'd be good to learn with that.
If you want something that offers debugging that won't scare the piss out of beginners (because gdb has a sharp learning curve), I'd recommend Visual Studio Express.
But either way, I ran your code and nothing odd happened.
PostPosted: Thu Mar 07, 2013 2:11 am
C programming is a good language and if you want to expose more on this language try to more research and get the best book to master the C Library is with no doubt "The Standard C Library" by P.J. Plauger.
PostPosted: Fri Mar 08, 2013 1:49 pm
The best C book is this: http://www.amazon.com/C-Programming-Lan ... g+Language
