It is currently Sat May 18, 2013 3:33 am
Post new topic Reply to topic  [ 30 posts ]  Go to page 1, 2  Next
 Post subject: Dell REcovery partition question
PostPosted: Sun Jan 20, 2013 4:33 am
My Dell laptop (recently did a clean install to Windows 8) has a Recovery partition in addition to an OEM partition and the OS partition. The OS partition is "Primary Partition, Boot, Page File, and Crash Dump". The Recovery Partition is "Primary Partition, Active, and System".
Shouldn't the OS partition also be listed as active?
Can I safely delete the Recovery partition?
 Post subject: Re: Dell REcovery partition question
PostPosted: Sun Jan 20, 2013 10:11 am
Yes
PostPosted: Sun Jan 20, 2013 10:12 am
Dell did something that both made sense and does not make sense. The "Active" partition is where your boot loader is. It shouldn't be with the OS partition, because if the OS partition poops out, it makes troubleshooting harder (the boot loader also contains the recovery environment). The reason why it's in the recovery partition is because it makes the factory reset easier. Technically the recovery environment is smart enough to discover all partitions to find the system image... which is where the "doesn't make sense" part is.
So can you delete it? Yes. But you now presented yourself with two problems:
  1. You can't restore your computer. Unless you happen to have a spare Windows disk around somewhere.
  2. You'll have to fix your boot loader, which requires a bootable recovery environment or putting it into another computer which you can do all the fun stuff in command line.
PostPosted: Sun Jan 20, 2013 10:28 am
I have a Windows 8 upgrade disk, and I also made a system recovery disk. I don't have any idea how to fix the boot loader. So I'm inclined to leave things as they are.
PostPosted: Mon Jan 21, 2013 4:29 pm
It's a snap.
Don't acquiesce.
PostPosted: Mon Jan 21, 2013 5:45 pm
kleinkinstein wrote:
It's a snap.
Don't acquiesce.
OK, so how do I fix the boot loader?
PostPosted: Mon Jan 21, 2013 6:44 pm
Did you look at the link?
PostPosted: Tue Jan 22, 2013 2:26 pm
It's a snap.
Don't acquiesce.
My bad. I didn't realize it was a link.
So, is my best approach to use fixboot in the OS partition, then make it active, and then delete the recovery partition? Or is there a different command I should use?
What else is on the recovery partition that results in it being shown as "System"?
PostPosted: Sun Jan 27, 2013 4:18 am
I'm still trying to figure out how to delete the recovery partition without hosing my computer.
Is my best approach to use fixboot in the OS partition, then make it active, and then delete the recovery partition? Or is there a different command I should use?
PostPosted: Sun Jan 27, 2013 12:39 pm
Follow this tutorial, option #2
PostPosted: Sun Jan 27, 2013 1:48 pm
Do I first use fixboot in the S partition, and then follow option 2?
What else is on the recovery partition that causes it to be shown as "system"?
PostPosted: Sun Jan 27, 2013 2:24 pm
The boot loader.
PostPosted: Sun Jan 27, 2013 4:05 pm
LatiosXT wrote:
The boot loader.
So, if I understand this, I need to move the bootloader from the recovery partition to the OS partition - or use fixxboot to create a bootloader on the OS partition. Then make the OS partition active, and then delete the recovery partition. Is that right?
PostPosted: Sun Jan 27, 2013 4:30 pm
No. Do this: https://social.technet.microsoft.com/Fo ... eae63a0c4e
You do not want the boot loader on the same partition as the OS. If the OS partition goes kaput, it makes recovery a lot harder.
PostPosted: Sun Jan 27, 2013 6:36 pm
How do I do this without losing my existing OS partition?
PostPosted: Sun Jan 27, 2013 6:52 pm
Alright, here's the complete list of steps to do this.
  1. Shrink the partition 100MB. You can do this in Control Panel → Administrative Tools → Computer Management → Storage → Disk Management. Otherwise use some other utility like Partition Wizard or something
  2. Open up Command Prompt as an administrator (right click on the shortcut, select "Run as Administrator")
  3. Enter in "diskpart"
  4. Enter in "list disk". Find the number of the disk the OS is on
  5. Enter in "select disk <# that OS is on>", so if it is disk 0, enter in "select disk 0"
  6. Enter in "create partition primary size=100"
  7. Enter in "list volume", find the number this new partition was assigned.
  8. Enter in "select <# partition is on>", so if it's volume 1, enter in "select partition 1"
  9. Enter in "format fs=ntfs label="System" quick"
  10. Enter in "active"
  11. Enter in "list volume". Your OS partition should have "Boot" in the info column. The system partition should have "System" in the info column
PostPosted: Sun Jan 27, 2013 7:24 pm
Thank you! One last question - does the above steps reformat the recovery partition, or do I still have to delete the recovery partition once the above steps are done.
I'm trying to make sure I do this right and not mess up my laptop.
PostPosted: Sun Jan 27, 2013 8:03 pm
You still have to delete the recovery partition. In fact, you should delete it first, expand the OS partition, then shrink it.
If you delete the recovery partition and then make the system partition, you can't expand the OS partition.
PostPosted: Sun Jan 27, 2013 8:13 pm
Expand the OS partition to account for the previous recovery partition space, and then shrink it by 100MB?
PostPosted: Sun Jan 27, 2013 8:25 pm
Expand the OS out to fill the rest of the empty space, then shrink it by 100MB.
