It is currently Tue May 21, 2013 6:02 pm
 Post subject: hard d rive
PostPosted: Fri Jan 25, 2013 11:01 am
Weirdest thing, not a problem yet, hard drive keeps kicking in every 2 minutes or so like software is loading, normal sounds, last for just over a minute then cycles again. Been doing it for about 24 hours, should i be worried??? Am I about to lose the hard drive??
 Post subject: Re: hard d rive
PostPosted: Fri Jan 25, 2013 4:59 pm
Could be a virus, update your anti-virus and run it. I would also install Malwarebytes, update it and run it too, get the free version.
PostPosted: Fri Jan 25, 2013 5:22 pm
It could also be a background process if you're not doing anything intensive. For instance, Windows will defrag your hard drive in the background.
PostPosted: Fri Jan 25, 2013 5:34 pm
I had my HDD light flickering on a regular basis about every 30 seconds and couldn't figure it out, turned out to be a bad SATA cable. Might want to install a new cable and see if that helps the issue.
PostPosted: Fri Jan 25, 2013 5:53 pm
Fire up Task Manager to pinpoint what's running in the background or System Explorer (download and run as portable) to really peel back all your activity and occurrences.
PostPosted: Sat Jan 26, 2013 3:04 am
Thanks guys! Just recently got rid of a nasty browser hijacker, ran Malewarebytes, AVG free, and Spybot, got rid of almost everything ( couldn't remove something with Spybot, assumed Malwarebytes got rid of it), this morning sounds have changed to every couple seconds for a couple of seconds, just won't seem to spin up, even defragged entire drive last night. I'm afraid to shut it down, thinking it won't start up again, gonna pick up external hard drive on the way home today and I am running the above programs again, but it sounds as if the hard drive is about to fail!
PostPosted: Sat Jan 26, 2013 6:04 am
1st and foremost, clone the drive over to a new one to secure your data before doing anything else.
2nd, run CCleaner with CCenhancer, then run Jetclean, then run System Ninja and now the drive will be squeaky clean
3rd, run Auslogics Disk Defrag + Optimizer via portable mode.
All these apps are free.
4th, do any of these noises sound like yours? If so, your EOL is near.
PostPosted: Sat Jan 26, 2013 6:12 am
I would go to the hard drive manufactures site and download and burn the diagnostic iso to a disk and run the diagnostic. Run both parts, the 90 second part first, then the second long running part of the diagnostic. The program will tell you if the drive is failing or not. The second part takes a long time, so go watch a movie.
Disk Management has a rudimentary disk diagnostic that will give you an indication of the drive...healthy, ectra.
PostPosted: Sat Jan 26, 2013 11:28 am
^ Yes, always a smart move. Even I overlook the obvious sometimes.
PostPosted: Sat Jan 26, 2013 1:59 pm
First off, thanks guys, downloaded all the free stuff, running the diagnostic now, all viruses, spyware are negative, bought a WD 2 TB External for $129.00, gonna burn rescue discs as soon as diagnostic is done. Not sure what clone means. Just use the backup feature for the new HD??? Then run the free stuff on the new drive?? Ironic my 1 TB HD is a Western Digital, but I couldn't pass up the price on 2 TB external with 3 yr warranty. Also the sounds wouldn't play back, but from the descriptions, none of them match my sound and knock on wood, it is still functioning!! Awaiting further instructions.
Murf
PostPosted: Sat Jan 26, 2013 2:57 pm
What it is, http://en.wikipedia.org/wiki/Disk_cloning
Use this, http://support.wdc.com/product/download ... p?swid=119
PostPosted: Sun Jan 27, 2013 8:14 am
Just got off live chat with HP support, seems my recovery partition is corrupted, nothing they can do for me, I must purchase the recovery discs. Anyone remember when they came with the system?? You don't even get real user manuals anymore. Anyways, while hooking up the USB cable for my external hard drive, I noticed it is one of the cooling fans making the noise and cycling every couple seconds, not the hard drive or optical drive. Gonna back up anyways before that fails, any suggestion on which direction to go??? Thanks again!
Murf
PostPosted: Sun Jan 27, 2013 8:30 am
Just FYI, I happened to download Piriform Speccy at about the same time this stuff started just to monitor my system and unbelievably the fan comes on when my motherboard temp reaches 71 degrees C and then shuts off when it goes to 70 or below, this noise is driving me crazy!!
PostPosted: Sun Jan 27, 2013 12:15 pm
Just change your fan speed/temp profile in your bios or with Speedfan.
PostPosted: Sun Jan 27, 2013 4:13 pm
Finished with cloning, now desktop is locked into the HP startup page giving me choices from F9 - F-12 and escape but nothing happens when I press these buttons, don't know what happened. It almost seems as though the HP was wiped clean although I don't know why. Anyways, hooked the external HD to my laptop and all my files were saved in separate partitions, OS, Recovery and System. Gonna try to figure out how to unlock or convert these files so I can actually use them. The ongoing saga, unfortunately I can only consider myself an advanced beginner, so any help from here would be greatly appreciated. Murf
PostPosted: Mon Jan 28, 2013 5:12 am
If you need an OS here are two places to buy win 7 32 or 64 bit:
http://www.missionsofts.com/microsoft-w ... 4-bit-oem/
http://www.newegg.com/Product/Product.a ... 6832116992
Win 7 is half way down the page, get the OEM version using either site.
You can go to your motherboards website to get the appropriate drivers and the video cards site for the drivers for it. You never gave your specs so we don't know what we are trying to fix.
Users browsing this forum: Google Adsense [Bot] and 4 guests
