It is currently Wed May 22, 2013 1:17 pm
Post new topic Reply to topic  [ 56 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: computer build
PostPosted: Wed Jan 23, 2013 10:40 am
i really don't want to go over 700$
PostPosted: Wed Jan 23, 2013 10:56 am
You can fit an ssd. I'm sure you want somthing more than this, so list me the parts and prices you're thinking at this moment...not just links. Make it easy for me.
Budget Build
Intel Core i3-2120, $110
ASRock B75M-DGS, $55
Samsung 8GB 1600, $29
Radeon HD 7750, $85
Barracuda 1.5TB, $65
Corsair CX430, $20
Samsung SH-222, $14
Rosewill FBM-02, $25
$403 dGPU
$318 iGPU
PostPosted: Wed Jan 23, 2013 11:01 am
Sentey Optimus Extreme Division Tower Case 49.99
ASUS M5A97 LE R2.0 AM3+ 89.99
HIS H785F1G2M Radeon HD 7850 1GB 256-bit 171.97
AMD FX-6300 Vishera 139.99
ARCTIC ACFZA30 24.78
Rosewill Stallion Series RD600 600W 54.99
Crucial Ballistix Tactical 8GB 47.99
that's the build i was hoping for without the HDD
PostPosted: Wed Jan 23, 2013 11:37 am
Budget Build
Radeon HD 7750, $85
Corsair CX430, $20
Samsung SH-222, $14
$403 dGPU
$318 iGPU
hmmmmmmm thanks for the little build on your tag i read over that motherboard it can hold i5 3570
but do you no how many fan's it can hold ?
PostPosted: Wed Jan 23, 2013 1:36 pm
You can afford the 250gb 840 @ $150 w/promocode AFTBEXC123. Don't delay, this $40 savings ends 1/24!
3, http://www.newegg.com/Product/Product.a ... k=B75M-DGS
PostPosted: Wed Jan 23, 2013 1:40 pm
is that without the cpu cooler or with ?
PostPosted: Wed Jan 23, 2013 1:49 pm
Click the link, everything is there. Pssst, buy the 840 ssd today! The 250gb has never been this low and you're on a tight budget. Ssd's change your computing life!
PostPosted: Wed Jan 23, 2013 2:08 pm
well i would love to have that SSD but now that i look at it lowering my fps in games for just loading speed doesn't seem smart maybe one day when i have more money i will buy a SSD
also would a stock cooler be good for the i5 3570 or will it heat up with just two fans ?
PostPosted: Wed Jan 23, 2013 2:14 pm
SSDs won't lower your FPS in games. How can it? Everything that the game needs to run will be in RAM. If anything, SSDs help increase your average FPS or even helps getting rid of stuttering from streaming (if the game data is on the SSD). If there's anything an SSD really does for your system, it helps make it more responsive.
As for cooling, yes the stock cooler is good enough for the Core i5 (because if it isn't, then Intel should've had a class action lawsuit a long time ago). And you should have at least some airflow in the case.
PostPosted: Wed Jan 23, 2013 2:21 pm
to get a SSD i would have to drop my 7850 to a 7770 = less fps
PostPosted: Wed Jan 23, 2013 2:27 pm
thinking i will use the 180mm side fan for intake and a 140mm on the top for outtake
PostPosted: Wed Jan 23, 2013 4:42 pm
well all the parts should work together right ?
PostPosted: Wed Jan 23, 2013 6:44 pm
where is everyone
PostPosted: Wed Jan 23, 2013 8:49 pm
Just want to check what is the best fan maker ? Corsair,cougar,coolmaster or someone else ?
PostPosted: Thu Jan 24, 2013 5:55 am
Define best? Speed, sound, static pressure, build, color, warranty, for cpu cooler, for case, 3-pin, 4-pin, what? If you want all of the above, these are the best kept secret.
PostPosted: Thu Jan 24, 2013 10:43 am
Cougar seems good for the cooling and outtake
PostPosted: Thu Jan 24, 2013 1:28 pm
someone told me 2 fans and a stock cooler will be really hot
PostPosted: Thu Jan 24, 2013 1:36 pm
Define "really hot". Intel's CPUs will start hitting thermal thresholds at 90C, at which point it'll desperate underclock itself. 100C is about the maximum thermal load. Stock coolers will sit around 50C idle and 70C under load. A decent aftermarket air cooler will shift those about 20C down. The only thing you're buying when you decrease the part's operating temperature is its useful life. Running hot or cold doesn't do anything to performance until you hit the upper thermal threshold.
For most applications, a stock cooler is fine.
PostPosted: Thu Jan 24, 2013 1:41 pm
well i will be playing planetside 2 very cpu eating game but the stock cooler should be ok or should i get a aftermarket cooler to make sure ?
PostPosted: Thu Jan 24, 2013 1:42 pm
You're paranoid, get a Cooler Master Hyper 212 Evo.
