It is currently Sat May 18, 2013 10:06 pm
 Post subject: itunes movies and hdcp
PostPosted: Wed Jan 23, 2013 9:13 am
im using win 7 pc with amd 7950 video and hdmi
connect to denon av receiver when i try to download
itunes movies either cant cause it does not
see my 3d hdtv as hdcp ready or if does download
sound skips and fades on playback
any ideas?
 Post subject: Re: itunes movies and hdcp
PostPosted: Wed Jan 23, 2013 9:23 am
Silly thing to check, but make sure the AV receiver is HDCP ready.
Otherwise plug the HDMI cable directly into the TV.
PostPosted: Wed Jan 23, 2013 10:08 am
Is your TV truly hdcp ready, double check, you'll be surprised how few really are. HDCP errors are notorious with iTunes HD content. I won't even begin to troubleshoot, since there are thousands of unsolved cases. Just poke around the Mac'ish forums for all the nightmares. CrApple simply doesn't care because they don't need to - as they are not in the hdtv market, yet anyway. So, if you are hdcp ready and compliant, you may be SOL and have nobody but Cupertino to thank for the fisting.
