It is currently Tue May 21, 2013 10:19 pm
 Post subject: How to unlock the fourth core,
PostPosted: Tue Jan 22, 2013 9:33 pm
Hello, this is a first time post, I hope I'm in the right place for this. I upgraded my system and would like to know how to unlock the fourth core on my Athlon II X3. My mobo is an ASRock 770 Extreme 3, memory is G Skill ripjaws 1333, HDD is WD Caviar Black SATA2 500gigs 32mb cache, vid card is HIS 4670, sound is Creative Labs, power is Thermaltake Toughpower modular 750 watt and OS is Win XP 32 bit. It's not much but I did OC the chip from 3.3 to 3.6 gigs and is stable with a Cooler Master 212+.
 Post subject: Re: How to unlock the fourth core,
PostPosted: Tue Jan 22, 2013 10:28 pm
There's a reason why that fourth core is disabled. At best you'll actually get it, at worst, you won't have a system anymore because the core screws everything up until you buy a new CPU
If you're fine with this and agree that if your system does go kaput, you're the only one responsible for it, then it's in your BIOS settings, but not all motherboards have that option.
PostPosted: Fri Apr 12, 2013 4:03 pm
To unlock that fourth core is usually just a setting in the BIOS/UEFI. On my little Asus M4A88TD-M that's how simple it is anyway.
I don't see a huge downside to unlocking a lower quality core most of the time. I have a 3.2Ghz Athlon II X3 450 Rana that it unlocked the core and still serves and does an occasional game just fine. What it can't do any more is overclock very well. I can get 3 cores up to the 3850 area, but with 4 cores it feels pretty limited to 3.4. All it does at that point is fall on it's face and pretty much instantly reboot.
IMO, I'd rather run around with faster yet fewer cores than be limited by speed of a limping 4th core. If you are bellying up to the computer for a few hours of editing media or running some long render that will utilize that core better, then just reboot, lower clocks, enable core, then boot up. Profiles really smooth this process out. I have 3 profiles which are stock, 3.8x3, & 3.4x4. Takes just about 1m to do the whole process and shift modes.
