It is currently Mon May 04, 2015 3:11 am
 Post subject: P4 2.4C overclocking
PostPosted: Thu Jul 15, 2004 1:02 pm
what's a safe voltage to take this CPU to? i'm getting some reboots when oc'ed at 3.0ghz with 250mhz FSB running at default voltage (1.60? i'm not even sure).
could it also be a lack of power from the PSU? it's an Antec 380w that came with the Sonata. if it was overheat, i'd think that it freezes instead of reboots.
memory is Kingston HyperX PC4000, 2 sticks of 512 each.
want to be able to keep it at 3.0ghz.
PostPosted: Thu Jul 15, 2004 2:09 pm
Contributing Writer
Contributing Writer
Both the 3.0GHz (D1 stepping) and 3.2GHz default vcore is 1.550. When I took my 2.4C to 3.4GHz, I was at a vcore of 1.66 (according to Asus Probe - can't remember what I put it at in BIOS).
If raising your vcore doesn't help, look your RAM voltages. Your sticks may need some more juice.
 Post subject: Re: P4 2.4C overclocking
PostPosted: Fri Jul 16, 2004 6:57 am
Generally bumping the VCore on the O4C's doesn't help that much (unlike the older socket A Athlons).
I personally saw no increase in overclocking headroom even with my voltage up to 1.7V.
PostPosted: Fri Jul 16, 2004 11:21 am
my P4C goes up to 3.0 (250fsb) no problem on default everything else. yet, it refuses to go above that...it has a screaching beep if i put it any higher...
PostPosted: Fri Jul 16, 2004 12:25 pm
[quote="cigar3tte"]what's a safe voltage to take this CPU to?/quote]
I'd say 1.6 is safe. My 2.4C makes it to 3.2 on stock voltage but my 2.4B don't overclock to ANYTHING unless I up the volts. I'm running 1.6 on a 2.4B and it's mighty fine. It was 1.575 but that wasn't enough. I'd try not to blow past 1.6. If you *need* to it may not be worth it. Still... a clean 3GHz feels like sex. :P
PostPosted: Fri Jul 16, 2004 12:37 pm
So *that's* what sex feels like?
Frankly, my enthusiasm for my eventual wedding night just dropeed down a dozen notches...
PostPosted: Sat Jul 17, 2004 7:54 pm
Million Club 2+ [PC]
What board are you using? I had also gotten some Kingston PC4000 memery and tried using it with my Asus P4P800 board. It didn't like anything above 225mhz fsb. I sent it back and got some OCZ PC3700EL stuff. I'm running at a 275mhz fsb with a VCore of 1.6.
PostPosted: Sun Jul 18, 2004 10:45 am
Contributing Writer
Contributing Writer
Makes me happy to see OCZ getting more widespread love these days. When I first started playing with their enthusiast line, it was a challenge at Delphi getting people to realize their reputation for 'hit or miss' is no longer accurate.
PostPosted: Mon Jul 19, 2004 4:34 pm
will you mary me? You "devil"ishly sexy man?
PostPosted: Wed Jul 21, 2004 7:24 am
I got to 3.12GHz @ stock voltage.
Increasing the voltage didn't help at all.
