It is currently Sun May 26, 2013 1:45 am
 Post subject: New at building PCs
PostPosted: Sat Jan 05, 2013 9:19 am
so I want to build a pc for myself instead of buying one at bestbuy or pcrichards. I want to do a bit of gaming on it but i mainly want it for music editing and producing, also for video editing and probably some photoshop work too. i have built one already and i want some feedback on it, you know if it would be enough to do these things. http://pcpartpicker.com/p/vWGB this has an asrock mobo but a budy of mine told me that msi mobos are more reliable.should i choose an msi mobo instead?
 Post subject: Re: New at building PCs
PostPosted: Sun Jan 06, 2013 11:18 am
What MSI mainboard did he recommend? Let's get all the facts on the table.
PostPosted: Sun Jan 06, 2013 7:32 pm
Asrock used to be known for their small form factor mobos (mATX & mini ITX). More recently, their standard ATX mobos have been quite good. MSI makes decent mobos, too, but never considered a top notch manufacturer. Recently, MSI has started this new MPower series where MSI will perform a burn-in test on 100% of the boards in this series to ensure they will work. This provides some added assurance that when you receive the board, it's been tested and should work. The trade-off is that these boards cost a little bit more than the non-tested counterparts.
Personally, if you find a board with decent reviews on Amazon or newegg (>70% 4 & 5s), and it has the functions you want, then I don't think it matters if it is ASRock or MSI.
Hope this helps.
PostPosted: Mon Jan 07, 2013 8:06 am
Good advice!
Also so you aware...on the whole, AsRock drivers outperform MSI.
PostPosted: Mon Jan 07, 2013 9:33 am
Eh, motherboards tend to perform the same regardless of who makes it. Except Intel's. Intel sucks at making boards.
PostPosted: Mon Jan 07, 2013 1:46 pm
he said I should get this mobo
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130643
and yeah you're right if people give it good ratings then it should be good right.
