It is currently Thu May 23, 2013 2:47 am
 Post subject: Ladder Logic programming
PostPosted: Wed Dec 19, 2012 6:05 pm
Million Club - 5 Plus
I know that this is a subject that might not get any answers from this forum. I wanted to see if anyone had experience programming in ladder logic. If you have, have you been able to bring any of this type of programming into V Basic or C+ ?
Thanks,
E
 Post subject: Re: Ladder Logic programming
PostPosted: Thu Dec 20, 2012 8:31 am
A quick glance on Wikipedia makes me think this looks like LabView.
But considering the operations are straight forward and binary, it would be a matter of translating what each component is supposed to do and return a value.
PostPosted: Thu Dec 20, 2012 12:49 pm
There is no C+ language. As for Ladder Logic in C++ or VB, don't know but it looks like you will probably be better off converting instead of trying to intermix things.
I worked with machines years ago that used Allen Bradley PLCs, and the guys who set up the units worked in Ladder Logic. I was always sort of curious about it, but when I looked at the code it was like nothing I'd ever seen. I'm curious as to what aspects of it you would replicate in a procedural C-like language. If there's a mapping that makes sense then I wouldn't be surprised if it's already been done.
PostPosted: Sun Dec 23, 2012 10:04 am
Ladder logic can provide actions for certain conditions (ie high oil temperature alarm). You can also perform standard logic gate functions like a an "and" or "or" gate. I would think these these can be easily replicated in VB or C++. Most PLC's these day can be programmed in either Ladder Logic, Function Block, or Structured Text. Or a combination of all three.
I know that there are some cards that allow for C++ programming to be embedded into the PLC and can have inputs/outputs to/from the ladder logic.
PostPosted: Tue Dec 25, 2012 9:18 pm
Thanks everyone for the reply.
I have found that (for me) keeping ladder and basic programming code separate with discreet options. I needed to get RS232 Ascii code from a computer that would be transferred to a PLC with a triggered time frame. I need to get this info from a VB program and send it to the PLC.
Thanks
E
