It is currently Tue May 05, 2015 6:38 am
Post new topic Reply to topic  [ 19 posts ]
 Post subject: What do you do to keep Windows fresh and clean?
PostPosted: Sun Jul 11, 2004 1:29 am
What do you do to keep Windows fresh, clean, and running smooth? Twice a week I do the following in this order:
Windows update
Clean IEs internet options(I only use IE for Windows updates BTW)
Clean Firefox internet options
Run Adaware
Run Spybot
Run Norton AV
Run Regscrub XP
Run Disk Cleanup
Run Diskeeper
Run Bootvis
I also update software as needed. I run XP Pro BTW. Maybe I'm a little to anal retentive? This routine only takes about 10min, and I do it on Wed and Sun. Any special routine yall do, or software you recommend? -Mac
 Post subject: Re: What do you do to keep Windows fresh and clean?
PostPosted: Sun Jul 11, 2004 1:44 am
I just defrag, that's it. Once in a while, if I want Windows to run fast, I'll use Linux :P
PostPosted: Sun Jul 11, 2004 2:11 am
I have an extra computer in my closet, I've been meaning to install Linux on. I just wanna try it and see what all the fuss is about. :) -Mac
PostPosted: Sun Jul 11, 2004 2:46 am
Head over to Alt.OS.Abode, lots of Linux loving people there!
PostPosted: Sun Jul 11, 2004 5:31 am
The Logik! Bot
The Logik! Bot
http://www.ultratech-llc.com/BrainWave/ ... html#Maint
PostPosted: Sun Jul 11, 2004 7:55 am
Contributing Writer
Contributing Writer
Windex and a rag or paper towel, whatever's closer. The trick is to scrub BOTH sides of the window. :wink:
As far as a serious answer, all the basics usual steps apply - defrag, spyware scanning, antivirus scanning, clean out cache and temp files. By far the best step you can take, however, is smart computing habits. In this age of rampant haphazard P2P use, unwise curiousity towards email attachments, naked systems (non-firewalled), and negligent surfing, there's only so much 3rd party programs and maintainence can do to repair preventable problems.
PostPosted: Sun Jul 11, 2004 9:53 am
i do a fresh windows install once every few months
PostPosted: Sun Jul 11, 2004 11:48 am
careful usage of the computer. then it keeps itself pretty clean
PostPosted: Fri Jul 16, 2004 10:53 am
refrain from downloading stuff from the Internet.
also keep a bottle of windex nearby... hehe.
PostPosted: Fri Jul 16, 2004 12:59 pm
prepare for some frustration. :D
also some feeling of accomplishment.
PostPosted: Fri Jul 16, 2004 5:49 pm
Bitchin' Fast 3D Z8000*
I follow the FDA's guidelines....
http://www.fda.gov/fdac/features/396_yst.html
Sorry... I just couldn't resist!
PostPosted: Tue Jul 20, 2004 4:08 pm
definitely (note that it is spelled correctly) not downloading much off the internet, p2p either. Run ad-aware and Spybot every once in a while and try to remove programs i don't use.
I found that by not using Kazaa (or even Kazaa lite) MUCH less spyware makes it's way to the computer. Actually the same goes for not using IE too.
~War
PostPosted: Tue Jul 20, 2004 4:15 pm
I can't believe no one made a comment about my joke?! How sad. :(
PostPosted: Tue Jul 20, 2004 4:49 pm
Hahahhahahaha i didn't even read that before sorry =(. That was really funny =P. What happens if it keeps coming back even after i do all that stuff???
~War
PostPosted: Wed Jul 21, 2004 10:24 am
~War
I hadn't considered that possiblility... :)
PostPosted: Thu Jul 22, 2004 8:59 am
I have always been partial to Windex :P
PostPosted: Tue Jul 27, 2004 10:47 am
Phoenix Foundation (Top 10)
Reinstalling the OS every other month or so. Actually, i have a new computer every other month, so either way works, lol. I like to use mine till i see something else i want to try, sell mine to next customer and then build new.
PostPosted: Tue Jul 27, 2004 11:57 am
I do a defrag and run pagedefrag on startup. I am on about a 8-9 month cycle of re-installing win2k. It runs pretty good most of the time. Another thing that can help is to keep your profile clean, and just replace the thing every once and a while.
PostPosted: Tue Jul 27, 2004 4:21 pm
i use the walmart brand crap...its just too damn cheap to not use
