It is currently Sun Jan 25, 2015 5:07 pm
 Post subject: win2k/xp oc settings
PostPosted: Mon Feb 07, 2005 8:43 pm
Hi All,
I'm thinking of doing an XP install (from win2000) and wonder if I should start the overclock process again? Or could I just leave my win2k oc settings as is, and boot up into XP.
Any experiences . . .
asus p4p800, p4 2.8 @ 3.192
1 gig generic
PostPosted: Tue Feb 08, 2005 8:04 am
I dont think you will have to do anything as long as you clocked it in your bios instead of thro the asus ai program you should be fine. If you did use ai then when you format the hdd it will revert everything back to default. Hopefully some other members will also have some advice as i am not 100% sure of this. But I am sure enough that i would do it on my own machine.
PostPosted: Tue Feb 08, 2005 8:06 am
I wanted to add that when I have changed my HDD out for a new one I did not have to reclock anything with an asus p4p800se board & win xp pro.
PostPosted: Tue Feb 08, 2005 11:05 am
Thanks everyone - I'm going to go for it . . .
I'll let you know how it works out!
