It is currently Fri Mar 27, 2015 2:50 am
 Post subject: Cooler Master Scout 2 Camo Edition
PostPosted: Thu Nov 08, 2012 11:05 pm
Its been a crazy summer & fall , and has been a blast with my family and friends, but back into the garage i go for a few projects. First project is the New Cooler master Scout 2 case, Having a military name and theme on the box i am definitely going with a camo theme
The case has a very sleek design and the Handle on top is great for lan gaming
I like the window, but since i will be watercooling i will be removing the fan grills and making it bigger
planning on removing one or both hard drive cages to make room for teh water cooling
Time to break it all down
using the scout insignia on the side panel
Camo paracord just need in a few other builds this will be perfect.
 Post subject: Re: Cooler Master Scout 2 Camo Edition
PostPosted: Thu Nov 08, 2012 11:08 pm
One would think growing up hunting a fishing i would be able to paint camo that wasnt the case lol . It took me three tries and several stencils before i begin to like the design .
sanded and Primed
black then brown
beige
a few touches up and it will be finished
Started cutting out the Guns and skull out of plexi. I ended up redoing the skull
testing the position
PostPosted: Tue Nov 13, 2012 5:42 pm
Touching up a few spots
getting ready to cut a bigger Window out , I did like how this look but going water cooling make a pretty easy descion for me to do it.
sorry a little blurry
The paint seems to flow to gether nicely
Camo, aluminum and Mesh from the case what could i make?
using the logo from the CM scout 2 box
no fingers where lost this time ( where my thumb?) jk
alittle touch of paint suggestion from my friend Haley!!!
More to come thanks for looking
PostPosted: Thu Dec 06, 2012 8:00 pm
A little break for the holiday Back to modding, Adding another cut out on the case . using a new blade and u can make some nice tight cuts with this.
Cm red
but the finish looks pretty good
Making room for the 240 rad for the front of the case, The optical drive bays made it too snug, i no longer use optical drives so one less bay wont hurt. so time to bring the dremal out
Fits now
Stayed tuned more to come!!
PostPosted: Thu Dec 06, 2012 8:18 pm
Next up The camo shroud for the interior!!! Dremal Time
mesuring it up
getting ready to make a bend, now wear did i put that bender( all 250 lbs of it)
It was alot harder to bend than i thought, I need to eat some more and try again
time to to connect them
test fit
sand down my edge
a little paint
a little camo
More to come!!!
PostPosted: Sat Dec 08, 2012 4:30 pm
More updates!!!!
finishing cutting out the window
Cut out a piece of smoked arcylic
Time to etch!!!
Lights out flashlight on( redneck light table (lol)
I used the etcher on teh ponited ends then bring out the dremal to finish the larger areas
I will finish the missed spots and clean it all up
Side window panel done!!!
PostPosted: Sun Dec 09, 2012 10:16 pm
This is looking awesome bro!
PostPosted: Mon Dec 10, 2012 7:53 pm
In order to be stealthy We need to add some silent fans, But clear isnt going to work.
One of my fav thing about these fans i sthe fan just pops off
Flat Black
next up sleeving
little ass screw drive does have a purpose
all yea camo sleeving
PostPosted: Wed Dec 12, 2012 4:59 pm
A couple of cool things about this pc , its headed to CES in las Vegas in Jan ( super excited). I will have to finish with the components when its gets back, It also entered inot the 2012 coolermaster case mod contest If you like it please follow the link on facebook http://woobox.com/qz4swg/vote/for/138536 also vote for your favorite thank you
Thanks for watching keep watching after the new year for the New components
PostPosted: Mon Dec 17, 2012 4:03 pm
Last nite to vote for the 2012 Cooler Master MOD contest. throw some support by casting a vote!!!
PostPosted: Wed Jan 09, 2013 6:29 pm
Well The case Made it to vegas and to CES 2013 in one piece,
Wes from Lanoc took some really nice Pics of the cases In the cooler Master Suite and I thought i would Share
Hope this will hold you over
Thanks for looking !!!
PostPosted: Tue Feb 05, 2013 1:24 am
+1 awesome!!
PostPosted: Sun Feb 10, 2013 11:34 am
Screw the case, I want to mod her.
PostPosted: Wed Jul 03, 2013 8:47 pm
They should hire you to sell scroll saws! you make the difficult look easy! I like the paint through the mesh trick, I've seen the painting trough dish mats but not that one. Now you have me thinking what else could be used. Top notch work.
