It is currently Tue May 21, 2013 12:46 am
 Post subject: WipeDrive stalls at 65%!
PostPosted: Sun Dec 02, 2012 6:47 pm
I'm using WipeDrive 3.0 to wipe out a HDD. I've used it before with success. This time it stalls out at 65% and sits there. Has anyone had this problem before?
 Post subject: Re: WipeDrive stalls at 65%!
PostPosted: Mon Dec 03, 2012 8:08 am
Is the hdd overheating? Often the case. I purposely wipe drives externally with a fan on the unit to whisk away all the heat. All that constant writing and rewriting erasing and re-erasing turns the platters into a scorching stove top. Why WipeDrive? Security issues were found with it about a year ago. I'm sure they fixed their algorithms by now, but I only use Dban, sometimes Heidi.
PostPosted: Mon Dec 03, 2012 8:17 am
I would check the temperature too, but if it's stalling at 65% every time, then I have a hard time believe it's just the temperature.
PostPosted: Mon Dec 03, 2012 1:58 pm
Yeah, odd that it's always 65% to completion. But it could be the software code. I've seen goofier things when a crash occurs.
PostPosted: Mon Dec 03, 2012 3:42 pm
Temps are fine. I've used it before without this issue.
PostPosted: Mon Dec 03, 2012 4:24 pm
Ditch it and Dban it.
PostPosted: Mon Dec 03, 2012 4:46 pm
Requires a boot disk. Why not use Eraser or CCleaner?
PostPosted: Tue Dec 04, 2012 7:48 am
Yeah okay, or Active KillDisk if you like the OS environment. I prefer Dban for the DOS interface since it can wipe multiple disks simultaneously, all with their unique method.
PostPosted: Tue Dec 04, 2012 3:56 pm
I finally got it to work. Ran it to just write over data files a few times, then ran it to do a full wipe and it worked.
PostPosted: Fri Dec 07, 2012 6:15 am
Cuul! I'll remember that trick. Thanks for circling back and closing out your issue.
Users browsing this forum: LatiosXT and 1 guest
