It is currently Sat May 25, 2013 11:23 am
 Post subject: Acer Aspire 7551-7422 keeps shutting down to desktop
PostPosted: Sat Dec 01, 2012 4:27 pm
I have a acer aspire laptop. It keeps shutting down to desktop or i get a grey screen sometimes blue. I paid for some computer company to look at it. They said the video card is going out. The problem is the video card and Motherboard are built with in each other so I would need both replaced. It would be very expensive for them to replace. ( meaning the labor Price ) I never thought to get a price for just the parts. I have been looking and cannot find anything I just want to make sure that this company is telling me the right thing. As I always say getting to much information when your dealing with computers is never enough in todays world. If anyone can help I would appreciate it. The model number is in the subject line.
Thanks,
Bigd7106
 Post subject: Re: Acer Aspire 7551-7422 keeps shutting down to desktop
PostPosted: Sun Dec 02, 2012 12:18 am
Probably looking at close to 200 for a new mb based on a quick ebay search.
PostPosted: Wed Dec 05, 2012 4:18 pm
any others have any ideas on a price ?
PostPosted: Wed Dec 05, 2012 5:21 pm
A few questions
  • Does it only happen when in Windows, or will this happen if you leave the computer on in BIOS?
  • Is the laptop under warranty? Open up an RMA ticket if it is.
PostPosted: Wed Dec 05, 2012 8:27 pm
its not under warranty already been there and tried. how do u get it to run in bios ?
PostPosted: Wed Dec 05, 2012 8:42 pm
It should say something on boot to press some key to enter setup. Usually it's either F2 or Del, but it differs.
PostPosted: Wed Dec 05, 2012 8:44 pm
If it does not do it when its in bios then what ?
PostPosted: Wed Dec 05, 2012 10:45 pm
Boot into safe mode in Windows and let it run. And if it still fine, then reinstall the video card drivers. If that doesn't work, then we can say your GPU is toast. Though you should probably just save up your money for a new laptop if this is the case. You could find a board for cheaper, but you're also taking a larger risk.
