It is currently Mon May 20, 2013 12:37 am
 Post subject: 24" LED monitor suggestions
PostPosted: Fri Nov 30, 2012 5:11 am
I am looking for a good/very good value LED 24" monitor. Price range $150 ~ $250. Any suggestions?
 Post subject: Re: 24" LED monitor suggestions
PostPosted: Fri Nov 30, 2012 8:31 am
LED's are a tricky beast in your budget. Do you want the most speed or do you want the best image quality? In your price range, you gotta pick one. Best image. Fast speed.
If want both, my favorite is the Ben-Q but you'll need to pilfer your couch cushions.
PostPosted: Fri Nov 30, 2012 10:36 am
There's also the question if you want 1080p or 1920x1200.
PostPosted: Fri Nov 30, 2012 2:25 pm
1080p is fine with me, what do you suggest, monitor wise?
