It is currently Tue Jun 18, 2013 10:04 pm
 Post subject: questions on new home network
PostPosted: Tue Nov 27, 2012 7:44 am
I am getting CAT6 strung around the house to set up my first network.
Some questions:
1. Can you recommend a good gigabit switch with at least 12 ports on it?
2. What would you use for a server? Right now I don't plan on streaming scads of movies or anything. I am looking for something that is cheap, quiet, small and easy to purchase or easy to build.
3. What OS should I use for the server? I have literally no Linux experience. I just want something simple and secure that I can set and forget.
4. Do I even have to have a server?
5. What software is necessary for a server besides antivirus? Do I need firewall software, or is that built into the switch?
Sorry if these questions seem silly as I am new to this.
 Post subject: Re: questions on new home network
PostPosted: Tue Nov 27, 2012 8:11 am
Probably http://www.amazon.com/Netgear-ProSafe-1 ... net+switch though at the same time I'm wondering why you need a 12 port switch unless you plan on that many servers.
I'd just get a 802.11n or if you really want, 802.11ac and hardline the servers.
It depends on how many requests you plan on handling at once and what those requests are. An Atom could power a NAS box. If you're looking for something that's more basic web serving, a lower-end desktop processor will do the job just fine.
There are plenty of guides for setting up Linux based servers out there, but if you really want to avoid that, your other options are Windows Home Server or mucking with Homegroups in Windows 7.
It depends on what you want to serve. But if you have to ask that question, chances are probably not.
OS's usually have one now, and a decent router should have one. I don't think switches do, but I haven't mucked around with them long enough.
PostPosted: Wed Nov 28, 2012 4:20 pm
Excellent. Don't forget to have good N-based wireless as well.
The suggestions already made are excellent choices, you can't really go wrong with gigabit switches these days. You will, however want to verify the total backbone bandwidth if you plan on having busy switches. Because a lot of switch say they're duplex, meaning all nodes can send and receive at the same time, this is largely true but to save cost some switch manufacturers actually cut down on all the interconnected traces. So a switch with 16 ports in full duplex should be able to have a total backplane/backbone bandwidth of 3200gbps...most only have half that.
And yes, it makes it a huge deal if you have only one switch to service all the nodes in your home.
Disk I/O will be a huge limiting factor. Consider running multiple drives, plenty of ram, and a multi-core CPU. Run those multi-drives in a performance RAID configuration like RAID 5 or better yet RAID 10. OR consider splitting your servers in two depending on what you are doing:
Server 1 - SMB/SAMBA file server, web server...etc. <--- CPU is less important, moderate amount of ram, phenomenal disk I/O
Disk I/O is essential here and is your sole concern when putting together a file server for use at home. If you decide to enable SSL for HTTPS on your web server, then clock rate on the CPU is very important.
Server 2 - Windows 7 media center. <--- multi-core CPU with fast processor, with lots of ram, decent disk I/O, fast network
The Windows 7 media can be spawned in multiple processes, and will also do transcoding if you have the appropriate transcoder plug-in installed. Multi-core is the most important with a fast CPU. Disk I/O is very important but not as much as network I/O either. Gigabit is fine, especially if you have a switch that can do Quality of Service on video and multi-media.
Linux for file and web server. No better time to learn than now.
Windows 7 Premium, Pro, or Ultimate so you get Windows Media Center. With a media center extender integration is seamless.
Most *nix based multi-media centers are capable, but not as painless as Media Center.
No. But it beats carrying everything on a laptop or having a desktop that your little brother can steal.
No. I'm even hesitant to run antivirus on servers...you do not get virus' by watching movies, or storing your personal information. You could get them if there is a digital rights management exploit, but anti-virus on a server will not catch that. Run anti-virus on your desktops, laptops, and clients because you generally get virus' because people's internet browsing and email habits are shit.
If you do end up running an email server, you will want anti-virus to monitor the server's transactions. Aside from that don't waste clock cycles and potential problems. Even on the file server, as long as you do not use it as a desktop, and you require clients/workstations on the network to have anti-virus there's a low likelihood of there being a virus problem.
Your firewall your NAT router with stateful packet inspection should be able to handle external intrusions to your internal network. Run it on your clients if you want, and run it on any windows based servers or any servers exposed directly to the internet (say a web server), but it's not necessary to run an application host based firewall on your servers.
