It is currently Wed May 06, 2015 3:37 am
 Post subject: Windows XP 70-270
PostPosted: Sat Oct 15, 2011 7:23 am
Team Member Top 100
Team Member Top 100
Windows XP is very old and is quickly getting replaced. But is it still worth it to get the Windows XP 70-270 MCP?
 Post subject: Re: Windows XP 70-270
PostPosted: Sat Oct 15, 2011 7:29 am
Yes. Many still use it, just like my granddad used Win98 until last year. He upgraded to 7.
PostPosted: Tue May 15, 2012 11:03 am
No support for XP is ending next year you are just waiting your time. Anyone that is using XP at this point has a really old computer and should prob upgrade
PostPosted: Wed Nov 28, 2012 3:34 pm
If you have a choice between getting Windows 7 and Windows XP...go with the 7 certification line. But if you just want to write a cert, then you can't go wrong with XP. But I would not prioritize any money you have toward certification in to it UNLESS you see a job posting out there that is asking specifically for Windows XP. And don't take the 70-270 certification lightly...it's one of the trickier certifications out there. Not as bad the 2003 security design certification, but still go in well prepared.
