Correct me if I'm wrong, but I've heard of GPUs going into the 80 degrees Celsius range without being permanently damaged (although it'll be slower at that temp). I'm pretty sure 60 degrees is within the safe operating range of the GPU, but contact EVGA and simply ask to make sure. Sound like a worried customer and they'll probably help you (something like "Hi, I'm seeing temperature readings of more than 60 degrees Celsius, is that normal for the card I have?")
Alternatively, more experienced people on the MaxPC forums might just straight up answer your question, and you wouldn't need to contact EVGA. That's just in case no one has a definite answer for you
