It is currently Tue May 21, 2013 2:25 pm
 Post subject: Help/Critique My New $1000 Rig
PostPosted: Sun Nov 18, 2012 6:38 pm
Hello I'm looking for help/critique on a new rig I'm thinking of building. It's primary use will be gaming, with maybe some mild encoding. Also want it to have OC capabilities to help's longevity a bit, but I will be having it run at stock in the present. I'm just looking for the best quality parts that I can purchase for this rig that will fit within the stated $1k budget (I know people's choices are subjective). The cheaper the total cost the better, obviously without sacrificing quality. The good thing I don't need a monitor and the keyboard/mouse is optional if I want to reuse some of the ones I have lying around the house. Here is what I have so far;
http://pcpartpicker.com/p/ogK9
For those that don't want to view the link:
PCPartPicker part list: http://pcpartpicker.com/p/ogK9
Price breakdown by merchant: http://pcpartpicker.com/p/ogK9/by_merchant/
Benchmarks: [url]http://pcpartpicker.com/p/ogK9/benchmarks/
[/url]
CPU: Intel Core i5-3570K 3.4GHz Quad-Core Processor ($219.99 @ Amazon) *
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($26.29 @ NCIX US)
Motherboard: Asus P8Z77-V LX ATX LGA1155 Motherboard ($114.99 @ NCIX US) *
Memory: Samsung 8GB (2 x 4GB) DDR3-1600 Memory ($35.99 @ Amazon)
Storage: Western Digital Caviar Black 1TB 3.5" 7200RPM Internal Hard Drive ($93.99 @ SuperBiiz)
Storage: Samsung 830 Series 128GB 2.5" Solid State Disk ($104.99 @ Adorama)
Video Card: HIS Radeon HD 7870 GHz Edition 2GB Video Card ($257.55 @ Newegg)
Case: Antec One ATX Mid Tower Case ($54.97 @ NCIX US)
Power Supply: Corsair Builder 600W 80 PLUS Certified ATX12V Power Supply ($61.98 @ Newegg)
Optical Drive: Lite-On iHAS124-04 DVD/CD Writer ($15.98 @ Outlet PC)
Total: $986.72
Total: * $896.72 If CPU and MoBo purchased from microcenter in-store near me
I'm at odd's basically on what to go with for the SSD, MoBo, Case and Brand of 7870. As far as the case is concerned, I want it to have good airflow, expandability, bottom mounted PSU, easy access to internals and somewhere to route cables. Also front USB 3.0 ports and tool less if possible.
*= *Note* I can get the CPU and Mobo from a microcenter near me. CPU for $169.99 and $40 off any Z77 board purchased with a ivy bridge CPU.
 Post subject: Re: Help/Critique My New $1000 Rig
PostPosted: Sun Nov 18, 2012 9:31 pm
Case is a good choice for your needs, motherboard is stable with a MaxPC recommendation and the SSD and RAM are tested good. You might want to swap out the WD hard drive for a Seagate Barracuda, I've heard they have more storage for the money. I can't comment on the video card.
Good choice of parts overall.
PostPosted: Mon Nov 19, 2012 9:28 am
Nicely done. But you're buying from all over. Way too many, cut it down to two + MC.
1. Get the 3570k from MC and pair it with the AsRock Pro-4 for $60. That Asus V board is sata port neutered.
2. Good HDD, but you are paying a premium. You can go Barracuda @ $75/1TB, $90/2TB, or $120/3TB.
3. Top drawer memory and ssd.
4. Not a fan of HIS, but that's here nor there since I have no data to back up my distrust.
5. Decent PSU for the money, but I'd steer you to more carefully consider Seasonic or PCP&C @ 600-650W
6. If you want a great case, land your eyes on the offerings from Fractal Design. Deal at the moment is the Arc Midi @ $56 shipped from Amazon.
7. All in, you have 5 friggin too many vendors.
PostPosted: Mon Nov 19, 2012 9:38 am
Ah yes, vendors. We should make others more aware of these. Try to use reputable vendors (NewEgg, TigerDirect, MicroCenter, Amazon if the seller looks legitimate). Also keep these as low as possible, 2 is probably my maximum. The more vendors you use, the more disorganized things become and you're more than likely going to pay for more shipping in total.
PostPosted: Mon Nov 19, 2012 9:33 pm
Thanks for the advice guys. As far as the HIS card, I had originally thought about the Gigabyte 1Ghz edition card, until I did some research on what reference card to get and so far I see people recommend Sapphire, HIS, Powercolor, MSI and EVGA. So I'm still up in the air about that. I will follow your suggestion on the PSU, and the HDD reason I went with that is because I heard Seagate's quality control has fallen off through the years since the merger with Maxtor? But I will take you advice on that also. As far as the vendor's that is what I was giving when I used the PC part picker site to build that example rig. In my own personal research I narrowed everything down between MC and NCIX, what you guys suggest as a good alternative to my RAM choice? Thanks for all the help so far, I appreciate it.
PostPosted: Mon Nov 19, 2012 10:16 pm
As far as RAM goes, I usually go with Crucial, Corsair, or Patriot. Samsung seems to be a highly recommended one too.
PostPosted: Tue Nov 20, 2012 7:17 am
No need to switch your memory, stick with those Samsung sticks. These 30nm dimms are simply kickass. I've got 4x4 @ 1996MHz, 9-9-9-28-1T, 1.36v. No other dimms can remotely do that. All the other brands are rapidly becoming exposed for the heatsink hype and inferior modules they are marketing. At $4.37/GB the performance is a steal.
PostPosted: Tue Nov 20, 2012 4:59 pm
If you live near a Micro Center you can pick up a 3570k for $169.00.
