It is currently Thu Jan 29, 2015 10:36 am
 Post subject: Problem with radio station on firefox
PostPosted: Mon Jul 19, 2004 7:53 pm
For some reason I cannot get WSPD live streaming feed to work on Firefox. I just installed it am I'm not sure what settings I might need to change to fix it.
It works great on internet explorer. Also Its not being blocked by a popup blocker. I have it disabled for this site
The station is here:
http://www.wspd.com/streamingisback.html
Thanks for your help
 Post subject: Re: Problem with radio station on firefox
PostPosted: Mon Jul 19, 2004 9:52 pm
No worries.
Go back to that link you posted, and click on the "click here to launch streaming player" link. It won't launch, but at the bottom left corner of Firefox will be a box with a square that has an "x" in it. Hover the mouse, and a text box pops up - "change pop up settings for this site." double click or right click, (can't remember which) and firefox will pop a box giving you the option to change cookie settings for this particular URL. Say "exempt," I think, and the player can be launched. Do be advised you'll get other opo ups from this site, but that's the price you pay.
I managed to get the registration screen, an ad, and what appears to be th eplayer itself to come up.
Hope this helps.
PostPosted: Tue Jul 20, 2004 8:08 am
OK I do see the red box popping up. So I guess I was was wrong about that. I thought I had turned the popup blocking off. Unfortunatley when I click the START STREAMING NOW link the window flashes, is blocked then foxfire returns to the last viewed page almost instantley. I managed to get the change popup settings tab to come up but before I can click the page is gone. There has to be a way to change pop-up settings through the options or some such animal.
I'll figure it out I guess. That is after all what makes computers fun and as a bonus it makes me smarter.
Thanks for the reply. I really do appreciate it. You've at least got me going in the right direction.
PostPosted: Tue Jul 20, 2004 8:18 am
I got it. I found the popp options under web settings and had to manually add www.streamaudio.com to the list of exemted sites.
I get the PIA popups but there are only a few and I'm perfectley willing to bite that bullet in order to get my Rush fix. Thanks
PostPosted: Tue Jul 20, 2004 8:37 am
Get the ieview extension for firefox and just right-click to open the link in IE.
PostPosted: Tue Jul 20, 2004 4:44 pm
You are welcome.
We arrived in the same place via different means. When I exempted those doamins, it didn't work for me until the box popped up asking me to exempt. I know one domain sends you to another, so perhaps I failed to exempt the right one under Tools -->Options-->Cookies.
Glad all is well.
