It is currently Fri Jan 30, 2015 2:01 pm
 Post subject: Building a gaming rig, which motherboard?
PostPosted: Wed Nov 14, 2012 6:58 am
CPU: core i5 3570k
GPU: Radeon 7870/7950
Mobo: Gigabyte GA-Z77X-UD3H or asrock z77 extreme4 (cost the same where i live)
after that its just 8gb of ram, and the usual suspects.
What im wondering is which MOBO is best for this rig? Gaming is the primary function, ill maybe overclock the cpu a little, but im no expert, so wont be much. Another question, would a 500w PSU be enough for this rig?
 Post subject: Re: Building a gaming rig, which motherboard?
PostPosted: Wed Nov 14, 2012 8:14 am
Flip a coin. Yes, really! They are just about identical, well of course except for the physical flimsy size of the Asrock. But now if you were thinking, you'd take a visit to ebay and pick-up a UD5H or Extreme6 for the same outlay, instead. Much better boards! MUCH!
Yes, 500w is more than enough. But to be sure, what is the make and model? Don't say Sparkle, Apevia, Inwin or some other junk psu.
PostPosted: Wed Nov 14, 2012 8:46 am
thanks for the answer! not sure about the psu. Looking at super flower, ocz or xfx. Dont really want to go over 120$ for the psu though.
PostPosted: Wed Nov 14, 2012 9:40 am
I have a Gigabyte GA-Z77x-UD5H with a 2500k processor and a Corsair H60 water cooler heatsink and I use the onboard overclocking utility to have my CPU run over 4.2G from its stock 3.7.
PostPosted: Wed Nov 14, 2012 10:27 am
Krudus wrote:
CPU: core i5 3570k
Earlier this year, Tom's Hardware did a 7 board roundup that included the Extreme4 & the UD3H's sister board GA-Z77X-D3H. Both boards (& a Biostar board) ended up in a three-way tie for best value. While the Extreme4 led most of the performance related benchmarks. The review also has some nice info on each board's overclocking seup.
Personally, I've switched from ASUS boards to Gigabyte & ASRock. Of the three, I'm most impressed with ASRock, tons of value, easy overclocking especially on the Extreme series boards, & better hardware than more expensive ASUS boards.
Bottom line, you can't go wrong with either choice.
PostPosted: Wed Nov 14, 2012 9:03 pm
Don't skimp on the PSU man. Super Flower? If it sounds cheap, it is...not matter the actual monetary value. You can invest a lot into this build and guess what powers it all? A piece of shit PSU I could build with $20 worth of parts (but probably be better). Pick a better PSU to feed your build. It doesn't have to be killer, Watts are relative, and QUALITY of the PSU is key.
AsRock are getting their shit together and are a value board to say the least. I have to disagree kindly with Chaosdsm here in that Gigabyte is in a state of flux with their products. In the past decade, they're up, they're down, they're average, they're down: If you pay $300, they rock but when we toy with $100 and a value board we get burnt easily. If you're on a budget and just stuck between the two, go AsRock. And if you're and average user, Zotac isn't a bad brand to consider.
It gets pretty much like Borderlands with motherboards for gaming rigs. The specs don't tell it all and you gotta lean on brands, price, level, and "color". Effectively, a gaming rig just relies on the graphics card and one slot on that board. You don't need USB 3.0 in 4 rear ports or any of that shit...you just want a solid board that pumps the graphics slot and utilizes memory to it's max. To me, that's Asus (Atlas if this were borderlands). Even the basic Asus trumps most average MOBO's in actual usage.
Let's not confuse enthusiast boards with game boards...or what you want: A board. You're not wanting to OC way out there, you're not running 6x GPU's...you're just leaning on one card in a motherboard slot. So you basically want an Intel chipped board and could possibly fit this in an mATX build with a fat graphics card.
PostPosted: Thu Nov 15, 2012 6:20 am
Look into ASUS they have great OC features and nice high end boards. I have a P5ND purchased in '08 it is running a Pentium 4 HT and it flies on the net and games like modern warefare with the help of a ddr3 1 gb video card. I paid $69.00 on sale and am pleased to have purchased it. So give them a look before a purchase.
PostPosted: Thu Nov 15, 2012 6:25 am
Price $124.00 @ Newegg.com
Model
Brand
ASUS
Model
P8Z77-M
Supported CPU
CPU Socket Type
LGA 1155
CPU Type
Core i7 / i5 / i3 (LGA1155)
Supported CPU Technologies
Turbo Boost Technology 2.0
Chipsets
North Bridge
Intel Z77
Memory
Number of Memory Slots
4×240pin
Memory Standard
DDR3 2400(O.C.)/2200(O.C.)/2133(O.C.)/2000(O.C.)/1866(O.C.)/1800(O.C.)/1600/1333
Maximum Memory Supported
32GB
Channel Supported
Dual Channel
Expansion Slots
PCI Express 3.0 x16
1
PCI Express 2.0 x16
1 @x4
PCI Express x1
1
PCI Slots
1
Storage Devices
SATA 3Gb/s
4
SATA 6Gb/s
2 x SATA 6Gb/s
SATA RAID
0/1/5/10
Onboard Video
Onboard Video Chipset
Supported only by CPU with integrated graphic
Onboard Audio
Audio Chipset
Realtek ALC887
Audio Channels
8 Channels
Onboard LAN
LAN Chipset
Realtek 8111F
Max LAN Speed
10/100/1000Mbps
Rear Panel Ports
PS/2
1 x PS/2 keyboard/mouse port
Video Ports
D-Sub + DVI
HDMI
1 x HDMI
USB 1.1/2.0
4 x USB 2.0
USB 3.0
2 x USB 3.0
S/PDIF Out
1 x Optical
Audio Ports
3 Ports
Internal I/O Connectors
Onboard USB
2 x USB 3.0 + 6 x USB 2.0
Other Connectors
1 x TPM connector(s)
1 x COM port(s) connector(s)
1 x CPU Fan connector(s) (4 -pin)
3 x Chassis Fan connector(s) (4 -pin)
1 x S/PDIF out header(s)
1 x 24-pin EATX Power connector(s)
1 x 8-pin ATX 12V Power connector(s)
1 x Front panel audio connector(s) (AAFP)
1 x System panel(s) (Q-Connector)
1 x MemOK! button(s)
1 x Clear CMOS jumper(s)
1 x USB BIOS Flashback button(s)
Physical Spec
Form Factor
Micro ATX
Dimensions
9.6" x 9.6"
Power Pin
24 Pin
Features
Features
USB 3.0 Boost - Faster USB 3.0 Transmission with UASP
USB BIOS Flashback - Simple Plug & Press - Hardware-based BIOS Flashback
CrossFireX Support!
Quick Info
Warranty
Limited Warranty period (parts): 3 years
Limited Warranty period (labor): 3 years
PostPosted: Thu Nov 15, 2012 9:19 am
Model
Brand
ASUS
Model
P8Z77-M
Compared to the Extreme4, that's not a gaming board... 1 PCI Express 3.0 x16 slot + 1 PCI Express 2.0 x16 that only operates at x4 = no SLI support & not a great option for 7series Radeon's (pci express 3.0)in Crossfire... not that Crossfire is even needed with a 7850 or better card on a single 1080p monitor.
Realtek LAN chipset :( My personal experiences with them is nothing short of bad.
Only 6 internal SATA connections - of course everyone's needs vary, but I'm currently using 7 internally & will be adding three 2TB drives for added storage space in the near future.
Compare the feature set of the ASUS & Extreme4... the ASUS ends up looking pretty lame.
Onboard debug LED - P8Z77-M = No - Extreme4 = Yes
external clear CMOS button - P8Z77-M = No - Extreme4 = Yes
LAN Chipset - P8Z77-M = Realtek - Extreme4 = Broadcom
RAMdrive utility - P8Z77-M = not included - Extreme4 = Included XFast RAM
LAN Optimization utility - P8Z77-M = not included - Extreme4 = Included XFast LAN (can improve online gaming)
Internal SATA Ports - P8Z77-M = 6 - Extreme4 = 8
Internal SATA 3.0 Ports - P8Z77-M = 2 - Extreme4 = 4
External SATA Ports - P8Z77-M = none - Extreme4 = 1 eSATA 3.0
Premium Gold plated Caps - P8Z77-M = No - Extreme4 = Yes (keeps external environmental corrosion away)
PostPosted: Thu Nov 15, 2012 10:02 am
I wouldn't say it isn't a "gamer board", as most gamers can't even use SLI or Crossfire effectively, at least with current pickings. And most don't have a 2560x1440 or higher monitor anyway. At least it has a PCI-Express 3.0 x16 slot. Although I'd argue that wouldn't matter, since you need to drop to PCI-Express 2.0 x4 before performance takes a significant hit... well I'll use that until someone does another test with PCI-Express scaling and GPUs.
PostPosted: Thu Nov 15, 2012 2:01 pm
@OP, hey you do know you're comparing apples and bananas, right? The Extreme4 is an ATX, while the ASUS P8Z77-M is mATX. So all the differences and deltas chaosdsm points out, exist for a form factor reason. And just for the record, there is an Extreme4-M which is mATX. Which by the way...is where it's really at!
@ chaosdsm, it drives me nuts that all non-Intel mATX boards are sans Intel Gigabit. Most all are either Realtek 8111E or 8111F. Hopefully Z87 fixes this as all my builds are downsizing fast.
PostPosted: Fri Nov 16, 2012 1:49 am
Bullshit... Extreme4 M (microATX) has same primary spec's as the full ATX version. The differences I listed are still there except for: they swapped the Broadcom LAN for Realtek 8111E :( and removed the diagnostic LED & external clear CMOS button. Hell ASRock even added a third PCI Express x16 slot to the Extreme4 M (only 2 x16 length slots on the full ATX version) sure it's the same 2.0 revision x4 data rate bs that's on the ASUS board, but it's still a 3rd x16 slot on a mATX board
BTW LatiosXT.... a decent number of gamers are rocking multiple monitors. Even just two 1080p montors spanned for 3840x1080 (4.147MP) or 3840x1200 (4.608MP) requires Crossfire with 7850 cards for smooth gameplay if you want maximum quality in certain games. Even on a single 30" LCD @ 2560x1600 (4.096MP) you'll still see minimum frame rates drop below 24fps in certain scenarios with two high end 1GHz core clocked 7850's in Crossfire.
PostPosted: Fri Nov 16, 2012 6:23 am
:oops: My bad, I had the the P67 specs in my head. Just sent off that build last week. We're comparing Z77, 77, 77, okay yes 77 here! I need more caffeine, less alcohol or perhaps just sleep.
PostPosted: Fri Nov 16, 2012 9:19 am
chaosdsm wrote:
Even just two 1080p montors spanned for 3840x1080...
Two monitors for gaming is horrible, especially for FPS games where you now have a gap where your cross hair should be Or worse, you can't see it because that gap is part of the rendering space.
