It is currently Wed Jun 19, 2013 1:28 am
 Post subject: Port Forwarding Password Not Working?
PostPosted: Sun Oct 28, 2012 11:22 am
I'm trying to forward a port on my router. Following these instructions, I typed my internal ip into my browser, and it asked my for a user name and password. I looked up the default user name and password for my router and typed it in, but it didn't work. I also tried my wifi username and password, and that didn't work. Anyone know what I can do?
 Post subject: Re: Port Forwarding Password Not Working?
PostPosted: Sat Nov 10, 2012 4:07 pm
Correct me if im not reading this correctly, but it sounds like you were not able to access your router to change your port forwarding settings. It is possible you changed the password for your router which would be why you cant login. If the default isnt working, you can reset the router back to factory settings with the button on the back or bottom depending on the model. If you do that, all settings will be reset and you will have to re-setup the wireless network and any other settings you changed but the default username and password will work again. If you go to the website for the router manufacturer they should have an instruction manual that will help with the reset.
PostPosted: Wed Nov 14, 2012 7:38 pm
Depending on your router's settings, you may only be able to change settings using a wired connection (i.e. not over wireless).
