This is the build I would recommend for you
ASUS DRW-24B1ST/BLK/B/AS Black SATA 24X DVD Burner - Bulk - OEM
$16.99
http://www.newegg.com/Product/Product.a ... 6827135204NZXT Phantom 410 CA-PH410-G1 Gunmetal Steel / Plastic ATX Mid Tower Black Trim Computer Case
$94.99
http://www.newegg.com/Product/Product.a ... 6811146093 Western Digital WD Black WD1002FAEX 1TB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
$79.99
http://www.newegg.com/Product/Product.a ... 6822136533 EVGA SuperClocked 02G-P4-2662-KR GeForce GTX 660 2GB 192-bit GDDR5 PCI Express 3.0 x16 HDCP Ready SLI Support Video Card
$229.99
http://www.newegg.com/Product/Product.a ... 6814130826CORSAIR Enthusiast Series TX650 V2 650W ATX12V v2.31/ EPS12V v2.92 80 PLUS BRONZE Certified Active PFC High Performance Power ...
$89.99
http://www.newegg.com/Product/Product.a ... 6817139020CORSAIR XMS3 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMX8GX3M2A1600C11
$36.99
http://www.newegg.com/Product/Product.a ... 6820233335ASUS P8Z77-V LK LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard with UEFI BIOS
$139.99
http://www.newegg.com/Product/Product.a ... 6813131837 Intel Core i5-3570K Ivy Bridge 3.4GHz (3.8GHz Turbo) LGA 1155 77W Quad-Core Desktop Processor Intel HD Graphics 4000 BX80637I53570K
$219.99
http://www.newegg.com/Product/Product.a ... 6819116504COOLER MASTER Hyper 212 Plus RR-B10-212P-G1 "Heatpipe Direct Contact" Long Life Sleeve 120mm CPU Cooler Compatible with Intel ...
$29.99
http://www.newegg.com/Product/Product.a ... 6835103065SAMSUNG 830 Series MZ-7PC128B/WW 2.5" 128GB SATA III MLC Internal Solid State Drive (SSD)
$89.99
http://www.newegg.com/Product/Product.a ... 6820147163Windows 7
$99.99
http://www.newegg.com/Product/Product.a ... 6832116986Subtotal: $1,128.89
You don't need the SSD so here's the cost without it
$1038.90
