It is currently Wed May 22, 2013 11:00 pm
 Post subject: Removing & Replacing WIN8
PostPosted: Sun Nov 04, 2012 8:48 am
Given that the WIN8 OS was imminent, I purchaged an EOM version of WIN7 - 10% discount from NewEEgg.
My intent was to format the HDD on my work related laptop & install WIN7 Home Prem. Am I, perhaps, over looking a potential problem?
Although my second question probably belongs in a different forum, I am going to take a chance of offending the moderator. The financial software which I use recomments an Intel quad core, 2.8GHz CPU. Is a laptop with a 2.4 or 2.6GHz QM CPU with Turbo boost into the >3GHz range going to be sufficient?
Thank you. Your imput is appreciated.
 Post subject: Re: Removing & Replacing WIN8
PostPosted: Sun Nov 04, 2012 8:52 am
There shouldn't be any problem. As for the software, those requirements are vague. So I don't think you should have a problem.
PostPosted: Sun Nov 04, 2012 12:42 pm
Make sure to do your fresh install the right way.
