It is currently Wed Jun 19, 2013 4:34 pm
 Post subject: Power supply orientation
PostPosted: Thu Nov 01, 2012 3:05 pm
Hello, I have an OCZ ModXstream Pro 700 power supply, and I plan on putting it into my Fractal Design R4 case. I was wondering which way the fan should point. Up or down? There are holes in the bottom of the case,and the case will be on a table top.
Does it even matter which way?
 Post subject: Re: Power supply orientation
PostPosted: Thu Nov 01, 2012 3:16 pm
Judging by the case, and the assumption that the fan is an intake, it depends on how much clearance you have from the bottom. If you're on a hard surface, from the bottom. If you're on a soft surface (carpet), from the top.
PostPosted: Thu Nov 01, 2012 5:27 pm
^ good smart advice! In all my R4 builds the fan orientation is always up. The probability is too high of just too much crap on the floor to justify a 180.
PostPosted: Thu Nov 01, 2012 5:56 pm
OK guys, I think I will be cautious and go fan side up. There's no mention in the book, or the OCZ web site I could find about that.
