It is currently Wed Jun 19, 2013 2:32 am
 Post subject: My vizio speaker bar subwoofer question.
PostPosted: Sun Oct 28, 2012 4:25 pm
well i purchased this speaker bar.
http://www.walmart.com/ip/Vizio-High-De ... r/11046520
it sounds pretty nice. I would like to add a sub, this sub.
http://www.amazon.com/Polk-Audio-10-Inc ... B0002KVQBA
I know nothing about this stuff. what do i need to make these two play nice.. also do you have any suggestions for any other subs that would work? also any cables or anything that you think i will need to by will you please let me know.
 Post subject: Re: My vizio speaker bar subwoofer question.
PostPosted: Sun Oct 28, 2012 5:20 pm
It's best you have a receiver.
PostPosted: Sun Oct 28, 2012 10:34 pm
I apologies i have zero idea what you mean when you say that... why cant i just go from the speaker bar to the sub with a single sub wire like vizio says i can.. i dont get this.. i needs mah bass...
anyone wanna recommend a sub that will hook into my speaker bar? and all the stuff i need to do that.
PostPosted: Sun Oct 28, 2012 10:48 pm
I think you should go learn more about home theater speaker setups if you don't know what a receiver is.
The cheap (and probably less quality) method is just to use a Y breakout cable so you can split the output of the TV to the sub and the sound bar.
PostPosted: Mon Oct 29, 2012 4:03 am
I know, I know, I know what a receiver is!
PostPosted: Mon Oct 29, 2012 5:14 am
Any forum where the normal users act like idiots for fun will eventually be filled with actual idiots who think they will be in good company.
PostPosted: Tue Oct 30, 2012 4:06 am
When I was looking into this stuff to tie together the 6 wall speakers in our house, I also had no clue. A receiver basically splits the audio from the source(TV, DVD, Blu-ray, CD players, etc) and sends it to the speakers and subs.
Shouldn't this topic be in the Multimedia Madhouse sub-forum?
PostPosted: Fri Nov 02, 2012 2:32 am
Million Club - 5 Plus
all you would need to connect that sub to the sound bar is one male to male RCA cable. "sub out" on the sound bar to "line in" on the polk sub. set the sub crossover to 70 hz for a start.
