It is currently Thu May 23, 2013 6:56 pm
 Post subject: Venting on Vishera
PostPosted: Tue Oct 23, 2012 9:19 am
http://www.anandtech.com/show/6396/t...-fx4300-tested
"Vishera is a step in the right direction for AMD, it manages to deliver tangibly better performance than last year's disappointing FX processor without increasing power consumption. Thanks to architectural and frequency improvements, AMD delivers up to 20% better performance than last year's FX-8150 for a lower launch price, while remaining within the same thermal envelope."
http://www.hardocp.com/article/2012/...c_overclocking
"Is Vishera a better part than Intel's Ivy Bridge or previous Sandy Bridge processors? No it is not, not even close. Intel still has a healthy lead in both Performance per Watt, and Instructions per Clock. AMD cannot best or match Intel on the desktop and keep in mind that AMD brings 4 more processing cores to the table than the Intel processors compared here today."
http://www.tomshardware.com/reviews/...view,3328.html
"I’m going to have to resign myself to forgetting what the FX brand once meant, though. Almost a decade ago, an FX was something that made Intel scramble to respond. It represented cutting-edge. And it set you back more than $700 bucks. Today, we have to ooh and aah over performance victories against the middle of Intel’s desktop line-up—its Core i5-3470 and -3570K—all the while shrugging off fairly severe discrepancies in energy efficiency. There. I’m done. Back to 2012."
 Post subject: Re: Venting on Vishera
PostPosted: Tue Oct 23, 2012 4:54 pm
Maximum PC had some interesting results, which made me think that AMD might be a viable solution for areas where CPU is more important than GPUs.
But the fact remains as a consumer level part, AMD's plans are flawed and they really need to rethink what they're doing.
PostPosted: Tue Oct 23, 2012 7:31 pm
Not really, even the 3570K with 4 less threads to work with & a 600MHz dissadvantage still holds it's own against the 8350 while using less power. Spend $100 more & the 3770K wipes the floor with the 8350 & still uses about 53 Watts less power. Sadly, the 8350 is a generation to late... it is what the 8150 should have been.
BTW... that extra $100 for the 3770K on a machine running 24/7 (for example a dedicated folding @ home box) at $0.12 per KWh would be made up in just over 18 months. So if you build a dedicated folder with the 8350 at a lower cost now, at the end of a 4 year run it would end up costing you a good bit more (possibly hundreds more depending on your cost per kWh) than a 3770K system despite the lower intial cost.
Chris (Toms Hardware review) is right, the old "FX" processors used to raise Intel's eyebrows, but the new "FX" is just something for Intel to laugh at.
I could have waited & gave the 8350 a try, but this is pretty much what I expected to see from it. This is why I chose to drop $900+ on a new LGA-2011 mobo & 3930K processor instead of spending just $220 to drop an 8350 into my old 990FX board.
Don't get me wrong, this is a step in the right direction, but AMD is barely taking baby steps when they need to be taking leaps.
PostPosted: Wed Oct 24, 2012 3:42 am
So right, but the chilling reality is that they are incapable of leaps. They will never challenge Intel again, ever. With the like of Haswell, 14nm Broadwell and Skylake and eventually 10nm Skymont in the pipe, AMD has no option but to unfocus, gracefully ignore and simply run away from the performance desktop and workstation market. They call it a strategy, but we all need to laugh, since it's nothing more than a desperate Hail Mary to find revenue on the low-end, tablet and mobile markets. The sad ending of this story will be Intel punching them in the neck here too and ARM stomping on their forehead. AMD is a lost sheep pumping out late products that suck and nobody wants.
PostPosted: Wed Oct 24, 2012 9:20 am
The stink of it is... if Bulldozer & now Piledriver had been true 8-core products instead of the shared FP bullshit they're crawling behind, they would have been competitive CPU's. True, they still would have lagged behind in IPC, and probably would have increased the power usage a bit, but they would have had an 8350 that would probably have fallen somewhere between the 3770K & the 3930K.
PostPosted: Wed Oct 24, 2012 12:44 pm
chaosdsm wrote:
...but they would have had an 8350 that would probably have fallen somewhere between the 3770K & the 3930K.
Indeed. And that would have been the such a sweeeeet spot of a proc for roundabout $335!
PostPosted: Fri Oct 26, 2012 5:12 am
i am looking at the benchmarks now(btw thx for links). i still have a amd+ mobo getting dusty, this will prob. b my last amd build.
i was expecting a 15-20% improvement, after a year wait, im very disappointed.
still if i can find a 8350 for $195 ill go for, if only to utilize my mobo.
amd, if your watching this, get a stick and beat yourself with it, you need 2b punished.
PostPosted: Fri Oct 26, 2012 5:25 am
I'm wondering something here, the overall performance of AMD's processors is low because of the IPC performance. I'm wondering why. The whole modules vs. core things shouldn't matter, because a lot of benchmarks in use tend to favor integer operations than floating point ones (Anandtech made this a point to test integer and floating point performance).
What's the flaw here? How can AMD be even more inefficient with their processors? The IPC performance of Bulldozer can be seen as worse at times compared to Phenom II.
Does AMD need better engineers? How can they still excel at GPUs, but suck at CPUs?
PostPosted: Fri Oct 26, 2012 6:58 am
because they bought their gpu division and stayed out of its engineering department. amd has always missed the boat in some things, consider cache, they never use enough, and never have. Intel learned long ago that more cache=faster.
PostPosted: Fri Oct 26, 2012 7:13 am
Uh. No. Intel needed more cache back in the day for two reasons (possibly)
  • Prescott's jaw-dropping 36 or something stage pipeline. If you missed anywhere in predictions, that's a massive penalty to take versus the 20 some stages found elsewhere.
  • Intel didn't have an on-die memory controller
Also, AMD has 8MB of L2 and L3 cache in Bulldozer. Intel only has 6MB in L3 and 256KB L2 for each core.
Not to mention, if you add more cache, eventually your latency for looking through it will be greater than just looking it up in RAM. Remember: you don't know if the data you need is in cache. However, it's always in RAM (well, usually).
PostPosted: Fri Oct 26, 2012 10:39 am
AMD problem is something called Intel. If there was no Intel or Intel wasn't as adept, AMD wouldn't suck so much. Look at the 3rd column from the right - 2011 R&D ($M). Notice what Intel's R&D budget is like. $8.4B. Now look way down the list at #9 and see what AMD's R&D budget is like. $1.5B and to get some idea as to how much of Intel's R&D budget is going into process node development, just look at TSMC at position 10 on the list.
Now what I really wonder is Why are Intel procs below $500 so crippled in features like AES, ECC, locked multipliers and so on? With the answer "because they can be". Thanks for nothing Intel.
