It is currently Thu Jun 20, 2013 12:52 am
 Post subject: Help Me BUILD ? :D
PostPosted: Sun Oct 21, 2012 1:08 am
Hey i just signed up on this site, im pretty sure someone here can help me out on this build i am going to make on my birthday soon. i just need to make sure everything is good ! so i will give you the specs i am going for . \\
CASE-NZXT Phantom 410 CA-PH410-B1 White Steel / Plastic ATX Mid Tower Computer Case
CPU-Intel Core i5-3450 BX806237i53450 Processor - Quad Core, 3rd Generation, 6MB L3 Cache, 3.10GHz (3.50GHz Max Turbo), Socket H2 (LGA1155), 77W
MOBO-MSI Z77A-G45 Intel 7 Series Motherboard - ATX, Socket H2 (LGA1155), Intel Z77 Express, 2667MHz DDR3 (O.C.), SATA III (6Gb/s), RAID, 8-CH Audio, Gigabit LAN, USB 3.0, PCIe 3.0, SLI/CrossFireX Ready
RAM-Corsair CMZ16GX3M4A1600C9B Vengeance Desktop Memory Kit - 16GB (4x 4GB), PC3-12800, DDR3-1600MHz, 9-9-9-24 CAS Latency, Intel XMP Ready, Unbuffered
GPU-GALAXY GTS 450 SLI
PSU-OCZ ModXStream Pro Power Supply - 700-Watt, Modular, Dual +12V Rails, SATA, 80Plus
HDD- 1TB WESTERN DIGITAL
DVD- STOCK
Please tell me if this build will work :D
 Post subject: Re: Help Me BUILD ? :D
PostPosted: Mon Oct 22, 2012 12:54 pm
The build will work but I would recommend a 7770 video card over http://www.newegg.com/Product/Product.a ... hics-Cards the 450 GTS unless you are going to have two of them running in SLI. You also didn't state on what your going to be using your build for whether its video editing or gaming so its hard to recommend parts.
I would recommend a Coolermaster Hyper 212 heatsink since the Intel stock heat sinks are pretty bad when it comes to cooling.
http://www.newegg.com/Product/Product.a ... -Heatsinks
PostPosted: Mon Oct 22, 2012 2:50 pm
You have a few odd choices here. What is your budget, what is your use case?
PostPosted: Mon Oct 22, 2012 4:09 pm
Actually the GTS 450 Is something i have now . and i will plan to upgrade it later.
and i am trying to build one for gaming.. mostly for high fps and that will let me play games on ultra and stuff.
but other then that . i am willing to spend $400-$600...
PostPosted: Wed Oct 24, 2012 11:02 pm
Imho, spend a few bucks more and get the i5-3570K CPU. Even if you are not planning to overclock, it is worth it to be able to.
I don't believe there is anything wrong with the MSI mobo and I am sure it's a solid board, but a lot of folks around these parts prefer an ASUS, Gigabyte or ASRock in terms of brands. The specs on the board look good though, and at $100 after reabte on the Egg, it's a good deal imho.
If gaming, you can save some $ and get 8 GB of RAM instead of 16 GB.
Even after upgrading your GPU later as planned, you can go with a slightly lower PSU. 600 watts or so should be plenty even if you upgrade to something like a GTX 680.
Add a Cooler Master Hyper 212 Evo or Plus cooler for your CPU, as the stock fan sucks.
Add an SSD for your OS and select programs. You can probably find a 128 GB Samsung 830 for about $80-90 on sale.
PostPosted: Sat Oct 27, 2012 6:51 am
Not really. If you don't OC, then you will waste money.
I agree.
