It is currently Tue May 21, 2013 12:41 pm
 Post subject: Help, With New Computer Build
PostPosted: Sun Oct 21, 2012 4:57 am
I am building a new computer, and I was wondering if these hardware are compatible with each other.
The build, will it work? Will it overheat? Do I need to upgrade?
Can I replace hardware that would be cheaper and have the same Speed?
I have keyboards, mice, cords, monitors, speakers, etc, etc..
All these Hardware can be seen on Amazon
MotherBoard---------------------------------------------------------------------------------------------------
ASUS Premium Motherboard DDR3 1600 Intel - LGA 1155 Motherboard (P8Z77-V PREMIUM)
http://www.amazon.com/gp/product/B0085JFM1U/ref=ox_sc_act_title_1?ie=UTF8&smid=ATVPDKIKX0DER
Ram-----------------------------------------------------------------------------------------------------------
Corsair Vengeance 32GB (4x8GB) DDR3 1600 MHz (PC3 12800) Desktop Memory (CMZ32GX3M4X1600C10)
http://www.amazon.com/gp/product/B0068ZWZY0/ref=ox_sc_act_title_4?ie=UTF8&smid=ATVPDKIKX0DER
HardDrive-----------------------------------------------------------------------------------------------------
Western Digital Caviar Black 2 TB SATA III 7200 RPM 64 MB Cache Bulk/OEM Internal Desktop Hard Drive - WD2002FAEX
http://www.amazon.com/gp/product/B004CSIG1G/ref=ox_sc_act_title_2?ie=UTF8&smid=ATVPDKIKX0DER
VideoCard---------------------------------------------------------------------------------------
EVGA GeForce GTX690 4096MB GDDR5 512bit, Dual GPU, 2xDVI-I,DVI-D,mDisplayPort, Quad SLI Ready Graphics Card Graphics Cards 04G-P4-2690-KR
http://www.amazon.com/gp/product/B007ZRO3U4/ref=ox_sc_act_title_9?ie=UTF8&smid=ATVPDKIKX0DER
SoundCard-----------------------------------------------------------------------------------------------------
ASUS PCI-Express x1 Sound Card XONAR ESSENCE STX/90-YAA0C0-0UAN00Z
http://www.amazon.com/gp/product/B00603QXPM/ref=ox_sc_act_title_8?ie=UTF8&smid=ATVPDKIKX0DER
PowerSupply---------------------------------------------------------------------------------------------------
Cooler Master Silent Pro Gold (SPG) 1200 Watts Modular Power Supply
http://www.amazon.com/gp/product/B003O8J11Y/ref=ox_sc_act_title_5?ie=UTF8&smid=ATVPDKIKX0DER
Processor-----------------------------------------------------------------------------------------------------
Intel Core i7-3930K Hexa-Core Processor 3.2 Ghz 12 MB Cache LGA 2011 - BX80619I73930K
Computer Case----------------------------------------------------------------------------------------------
Nzxt Technologies Phantom with Green Trim (Green LED) Enthusiast Full Tower Case - Phan-002Gr (Black)
http://www.amazon.com/gp/product/B004WO17UC/ref=ox_sc_act_title_3?ie=UTF8&smid=ATVPDKIKX0DER
CD Reader-----------------------------------------------------------------------------------------------------
ASUS BW-12B1ST/BLK/G/AS 12X Blu-ray Internal Burner with Disc Encryption, Black
http://www.amazon.com/gp/product/B004ZMG55I/ref=ox_sc_act_title_2?ie=UTF8&smid=ATVPDKIKX0DER
 Post subject: Re: Help, With New Computer Build
PostPosted: Tue Oct 23, 2012 12:46 am
What do you want to do with your build? As it is, it looks like you've just selected some of the most expensive parts you could find, which is probably not really what you need or want. Do you want a top of the line, high-end gaming rig to overclock and watercool and continously tweak inside and out? Do you want a mid to high-end gaming build that you build once and more or less forget about because you just really want to play new games and not have to worry if your build is good enough. If applications are a concern, what programs will you use and how?
What resolution and what settings will you game at? And what are your expectations on gameplay?
Have you considered a budget or range?
Perusing the parts you've selected, in almost any case, it's probably overkill.
