It is currently Sat Jan 31, 2015 9:55 am
 Post subject: Need Recommendation
PostPosted: Fri Oct 19, 2012 6:13 am
Seems the latest/greatest vid cards are for gamers playing 3D games and such. My rig is just a PC/Media rig. Half the time it has me on the net and half the time it's encoding HD for me to watch, usually doing all at the same time.
In the past, I've been getting the BEST vid cards cause with my rig, it has a lot of resposiblity. I could be watching a HD movie on my 42" HDTV while at the same time surfing the web, downloading files and maybe even watching video from YouTube.
A thought came to mind....why don't I get 2 "pretty good" vid cards instead of one top notch vid card?? I could plug the one card into my 42" HDTV which would encode HD movies and whatnot and I could plug the other card into my 26" HD monitor for the internet. The ONLY reason I got such expensive cards was to handle all of the work it had to do but if I got two pretty decent cards......you know what I am saying????
I was hoping members here could give an opinion as to the best option. Running one high end vid card hard, overclocked or two pretty decent vid cards at stock?
 Post subject: Re: Need Recommendation
PostPosted: Fri Oct 19, 2012 6:29 am
You don't even need a GPU. Just roll with HD4000 via an Ivy proc.
PostPosted: Fri Oct 19, 2012 9:39 am
^This. Independent GPUs are for gaming. Encoding video uses your CPU and integrated HD4000 graphics can easily handle watching movies/browsing the web.
PostPosted: Fri Oct 19, 2012 9:44 am
But, he has an AM3 processor...
The only reason to get a high or mid level GPU is GAMING or 3D Content Creation. Your GPU does not handling any encoding work, all encoding is done on your CPU, & even with Adobe Premiere Pro CS5 or newer, the GPU only handles the acceleration of certain effects. This will handle all your needs: http://www.newegg.com/Product/Product.a ... 6814130788
List of GPU accelerated effects in Premiere Pro CS5
Here is a list of the effects and transitions that can be accelerated by CUDA in Adobe Premiere Pro CS5, Adobe Premiere Pro CS5 (5.0.3) and Adobe Premiere Pro CS5.5 and later.
Alpha Adjust
Basic 3D
Black & White
Brightness & Contrast
Color Balance (RGB)
Color Pass (Windows only)
Color Replace
Crop
Drop Shadow
Edge Feather
Eight-Point Garbage Matte
Extract
Fast Color Corrector
Four-Point Garbage Matte
Gamma Correction
Garbage Matte (4, 8, 16)
Gaussian Blur
Horizontal Flip
Levels
Luma Corrector
Luma Curve
Noise
Proc Amp
RGB Curves
RGB Color Corrector
Sharpen
Sixteen-Point Garbage Matte
Three-way Color Corrector
Timecode
Tint
Track Matte Key
Ultra Keyer
Video Limiter
Vertical Flip
Cross Dissolve
Dip to Black
Dip to White
List of GPU accelerated effects in Premiere Pro CS5.5 and later
Here is a list of the additional effects and transitions that can be accelerated by CUDA in Adobe Premiere Pro CS5.5 and later.
Directional Blur
Fast Blur
Invert
Additive Dissolve
Film Dissolve
PostPosted: Fri Oct 19, 2012 3:38 pm
WOW......are you telling me that $40 card will do all I need? That's the 600 line that ends with the 690 that has 2 GPU's on it and is worth about $1,000.
I want my rig to rock super fast on the internet, download files like fire and watch HDTV on my 42" HDTV at the same time.
I'm running a Radeon 4890 HD w/1GB RAM which runs both TV and monitor. My rig is 3 years old. Man I always thought the vid card handled.......you know, all the video.
Question remains, is it better to have 2 half decent cards or one "mack daddy" card?
PostPosted: Fri Oct 19, 2012 4:10 pm
Video decoding can be offloaded to the GPU, but it's never clear when it does. Not that it matters, even a pitiful dual-core Atom could handle H.264 @ 1080p these days. Even if you can't do anything else while it's playing video.
Also you want your rig to rock super fast internet? Get a faster internet connection. You can throw in the fastest hardware on the planet, but if you're on 8Mbps, that's all you're getting. On a good day. So think about upgrading your ISP first.
