It is currently Mon Jan 26, 2015 9:28 am
Post new topic Reply to topic  [ 27 posts ]  Go to page 1, 2  Next
 Post subject: Project: Steampunk'd TJ11
PostPosted: Thu Oct 11, 2012 12:16 pm
Time for a good Steampunk mod. And what better case to use than the awesome Silverstone TJ11!
Big shutout to my sponsors!!
Performance-PCs is providing me with the BP mod kits, 240 and 360 rads and the Silverstone slim DVD bay.
[url="http://www.ekwaterblocks.com"]Image[/url]
EKWB is providing me with a EK-Multioption 250 Res and 90 degree fittings.
[SIZE="4"]Hardware[/SIZE]
Mobo: Asus Sabertooth P67
CPU: Intel i5 2500K
GPU: Unknown
RAM: 16GB Corsair Dominator 1333
SSD: Curcial M4 128 GB
PSU: Silverstone Strider 1200W
Fan Controller: Lamptron FC10
[SIZE="4"]Cooling[/SIZE]
XSPC EX480
EK-CoolStream 360
Another 360 rad
EK-Multioption 150 or 250
EK-RAM Dominator
EK-MOSFET Sabertooth P67
EK-Supreme LTX
2x XSPC 120mm radiator stand
[SIZE="4"]Misc[/SIZE]
Sleeving: MDPC-X
Yellow SMD LED Strips
Yellow LED bulbs
Sophisticated Finishes Rust Effect Kit
Old Vacuum Tubes
Lets start working! The first thing I did was do some testing with LEDs in the Vacuum tubes. Here is what they look like with an Orange LED in them. Orange is not the final color, yellow is but at the time I didn't have the Yellow LEDs in yet.
Next up was to see how the rust effect paint would workout. First lets try some fan grills.
The Paint
The Grills
Primer and Iron paint
Rust Paint
Since that test was successful I thought I should try an actual piece of the case. The dual PSU bracket seemed like a good test subject.
And the result
I am very confident in the results so I started doing more, but that's in the next update. Stay tuned by subscribing so you can see all the updates!
Cheers till then,
Fuga
 Post subject: Re: Project: Steampunk'd TJ11
PostPosted: Sat Oct 13, 2012 11:03 pm
Since testing is over its time to start on the case.
Its actually a good thing I'm modding this case because I got it used for pretty cheap. You would never get a good looking build out of this beatup case unless you paint/modify it. There are several screws missing, HDD bays missing and the front bezel was bent. I was able to fix the front bezel mostly and I ordered lots of new screws.
First thing to do is remove all of the buttons, connectors and cables.
Remove the mobo try and fans. I was going to not use the fans but I decided to make a midplate to hide them and that has cutouts for the fans. There will also be some Bitspower passthrough fittings for the tubing.
5.25" bays gone and mobo tray rails are out.
And here it is in pieces.
The first thing to do before you paint is get a nice coat of primer on the parts.
Next I started painting all the parts with the Iron base coat. This actually has iron particles in it which react with the Rust paint.
All the small bits.
And the large ones.
Next is the Rust paint. Its actually not paint. Its a chemical which looks more like blue water but you get the picture.
Just after 1 coat you can see it starting to work.
2-3 coats
5ish coats
And the first coat on the 5.25" bays
It starts the reaction only after maybe 5 minutes after being applied.
Lastly I'll leave you with some of my grill plans. I have a friend who does my laser cutting and he will do up a sick CAD drawing for me and I'll share it with all of you.
I'm going to install the 50mm fan on the motherboard so I need a grill to make it look nice. Also since I am keeping the internal 180mm fans I have to keep the side panel vents. I want to dress them up some otherwise they just look funny.
His will obviously look better than what I can draw :P
Cheers till next time,
Fuga
PostPosted: Sat Oct 13, 2012 11:36 pm
I'm super siked to announce that Performance-PCs.com is sponsoring me with some gear.
Now for the unexpected results. I needed to put a clear coat on the rust because it would rub off just like real rust. In doing so the color of the rust went from a orange/red/brown to more of a dark brown. I actually like this color because it looks more like leather. Let me know what you guys think.
Mid plate with clear on it and the mobo tray under it.
I liked it so I keep putting clear coat on the rest of the parts. Here is the mobo tray painted and assembled.
Still has a rust look to it.
And compared to the PSU bracket.
So while I was painting the rest of the parts I decided to start modding the "Thermal Armor" of the mobo.
Tape applied
And marked
And here are the final results. Not sure I'm going to keep the skinny piece between the MOS block and the CPU, it isn't perfectly straight and looks in like its in the way of the design. Not sure yet what I will do.
Not sure how I will paint it but here are a few things I figured out recently.
I'm going to paint all the water blocks gold!
I will paint the 2 ribbed parts of the exterior gold.
The front bezel, back side of the case and side panels will have wood grain vinyl applied.
The Thermal Armor will either be rusted, wood grain or covered in leather!
GPU back plates will be the same as the Thermal Armor.
Things I have ordered:
50mm fan for mobo
EX360 rad
EX240 rad
2x BP MCP655 mod kits
Silverstone Slim DVD Drive bay
Acrylic
Things I need to order
BP Dual D5 Pump top
more Turbine Master fans
EK Uni Brackets for RES
250 Res
Questions, Comments and Recommendations are welcome!
Fuga
PostPosted: Mon Oct 15, 2012 1:05 am
I have been debating on weather or not I would paint the radiators or not for a while now. Here is what the unpainted rad looks like with the fans and painted grills.
I didn't like the look so I decided to give the rad a make over.
I'm glad the letters are still legible.
With the fan grills on. These outside ones are just for looks and to protect the fins.
Fans attached.
Black fan grills on the inside fans. I was debating on painting the fans and inside grills but it would be a waste. By not painting them I can easily replace them and not worry about having to repaint them at a later time.
Got my MDPC-X sleeving in. I have no idea what the combo will be yet but I have lots of time to think about it.
The Yellow LEDs finally came in along with the 47 Ohm resistors for them.
I pulled one out right away and started testing with the vacuum tubes.
I know they still look a little bit orange in the photos but they are a really nice amber yellow in person. They will look great with the other LED strips I have.
Now for a bit of sponsor news. I was talking to Bitspower several months ago and all of a sudden, they stopped replying to me. Well just a few days ago they finally wrote back and we are in talks again for parts. I hope to get all my fittings and the pump top from them.
I also finally got EK to bite. I started talking shop with them. Not sure all what they will be providing but I'm hoping for at least GPU blocks since PPCs took care of my radiators.
What's coming next?
I'm going to finish modding the "thermal armor" on the mobo this weekend. I want to get a nice clean fit.
I ordered a few sheets of aluminium to make a sturdy midplate. (There will probably be acrylic on top of it. I have not decided yet)
I need to do more research into "wood veneer". Someone suggested that instead of using vinyl to give the case a more natural look. After looking at the prices, its not much more than the vinyl so I'm thinking hard about it. Here are 2 that I am looking at.
This one is already finished.
http://www.veneersupplies.com/products/Paper-Backed-Teak-Veneer-Quartersawn-4-x-8.html
This one requires a finish.
http://wiusa.com/curvwood/Library-Files/teak__flat_cut.htm
That's it for today. Hopefully I can get some more done this weekend since its a long weekend but there isn't much left to do on the inside. I need to decide/figure out the veneer situation so I can get the outside done. Oh and I'm waiting for gold paint to arrive. Once I get that I can do the water blocks and some of the case exterior.
Fuga
PostPosted: Mon Oct 15, 2012 1:07 am
Performance-PCs.com will go down as the fastest company to ship sponsor gear ever! I placed my order and got it not even a week later.
Here is the gear!
XSPC EX360 Multi Port and EX240 Multi Port
I like these rads because they have such a high FPI.
6 ports on each rad!
Up next is 2 Bitspower D5/655 mod kits
Installed on the stock pump tops. Temporary setup because I will be using a Bitspower Dual D5/655 pump top in the mod.
Finally the Silverstone Slim ODD and SSD/HDD bay. I really like this because I can fit my Slim ODD and up to 4 SSD/2.5" HDDs in it.
Thats all from them. More modding in the next update.
Cheers till then,
Fuga
Now I need your opinion! I got 3 different types of Leather fabric and I'm not sure which one to use. I'm going to post a few pictures of each and I'd like to hear what you have to say!
Option 1:
On the door
Close up
On the mobo
Option 2:
On the door
Close up
On the mobo
Option 3:
On the door
Close up
On the mobo
Please leave your feedback! I really want to know what you guys thing. The leather will cover the door panels, the front bezel and the motherboard's "thermal armor". Hope to hear from you guys!!
Fuga
PostPosted: Mon Oct 15, 2012 1:08 am
I got tons of work done so this update might be a bit big.... sorry but at least it has lots of pictures for you :D
Up first is the 50mm assist fan for the mobo.
You can see that the cable is quite long. So I need to fix that.
After I got it to the correct length I plugged it in and the wire instantly broke at the connector.
So I did it again thinking I screwed up but it happened again! So the fan is in the trash now and I ordered a new one from Xoxide and hopefully it will be better quality.
I cut and straightened out the part of the thermal armor by the MOS block. Looks good now.
Here is a shot of the RAM. Nice Corsair Dominator!
I wanted to do a test fit so here are all the blocks on the mobo.
Time for some sleeving so I got out my trusty box of MDPC-X sleeving and went to work. This color works best I think to kinda match the rust.
Next I painted the 360 and 240 rad, mounted the grills and fans on them and sleeved the fans. I'm short a few fans and fan grills so the 240 does not have them on it yet.
I also painted the XSPC rad brackets.
I've heard good things about the LutroO sleeving tool so I figured I'd pick one up and try it out. I'll be using it for the PSU sleeving.
Since I decided to paint the thermal armor to match the interior of the case I wanted to remove some of the little indentations on it. So I got out the Bondo and lathered it on.
Next I sanded it down just a little bit because I wanted to keep some of the imperfections.
I then coated it with primer and the iron paint.
And here it is after a few coats of the rust solution stuff.
Put some clear coat on and put it back on the mobo.
That's all for this update.
Here is what I'm currently waiting for to arrive:
Gold paint
Spray adhesive
50mm Fan
120mm Fan grills
Lamptron FC10
I'm sure there is more but that's all I can think of right now. I'm travelling for the next few days so I probably won't have any work done till next weekend. Hope your enjoying the mod.
Fuga
PostPosted: Mon Oct 15, 2012 1:10 am
Sorry for the delay in updates. We took a trip to South Africa for some medical appointments last week. Got to do a ton of things down there including visiting a Lion Park!! Was pretty cool to be able to pet some lion cubs.
On with the modding!
I picked up some UN Radiator mounting brackets which are so freaking awesome. They allow you to mount a radiator in your 5.25" bays.
And here it is.
Above it I put the Silverstone Slim DVD drive bay. The rad is touching it because I have to have enough room below the rad to put the pumps.
I decided to install all the rads to see how everything would fit. Here is the 4x120
A surprise will be going in this vacant spot :D
And the 3x120
Installed the PSU to make sure I had enough clearance for the connectors.
Indeed. There is enough room!
Somehow I forgot to do the rust effect to the back of the mobo tray so that is going on right now. Once its done I can clear coat it and it will be good to go.
I've been doing lots and lots of thinking on how I am going to run the loop. I figured that I need to bring the loop through the midplate twice but I didn't want you to be able to see it the second time. So I measured and drilled a hole above the 4x120 rad and connected it with a Bitspower D-Plug for now. I ordered a 25mm extension to go there.
And here you can see where the pumps will be. I measured and the Bitspower dual D5 pump top should fit under it. If not, I ordered a second EK D5 pump top and ill connect them together using some 90 degree fittings and extensions.
I received my Lamptron FC10 too! I'll be doing a review on it soon.
The last bit for this update are the door panels. I like the 4 small windows in the bottom of the side panels for the rads to get air but I decided to make them into one big window.
Then I added some MNPCTECH Round Modder's Mesh.
That's it for today. I have the spray adhesive coming for gluing the leather fabric to the case and the gold spray paint for the accents and the water blocks. That should all be here Friday so I can do a good bit of work this weekend. I'm also hoping that the pump tops get here by this weekend too so I can do some more testing to figure out exactly what I'm going to do.
Cheers till then,
Fuga
PostPosted: Mon Oct 15, 2012 1:15 am
This past week I have really been trying to use my DSLR Sony A350 better. I'm doing alot more manual shots to try and get better pictures. After this update let me know what you guys think.
Here are some pratice shots.
Now for the real update. I forgot to mention I got a 50mm fan for the motherboard.
I also ordered some cable clips that I saw in another build. I think they will help to keep all my cables nice and straight.
I orderd several sheets of 1mm aluminum so I could make a mid plate. (Got lots of extra incase I screw up.
Measured and marked.
Now I didn't take any of the cutting and bending as that is boring. So this is what it looked like after that.
Pretty level
After that I had to find a way to keep it stable so I added some tabs. I attached them with some JB weld. These ones will be secured to the 5.25" bays.
And this one is just to keep it in place.
Now it sits nice and flush.
Now you saw where I am putting the pumps so I drilled a hole for the fill port to the pumps.
And attached the pump.
Next I marked the spots for the fan holes. They are actually a little bit smaller than the 180mm fans because I need the floor space for cables, tubing holes and acessories but it won't effect the performance too much.
I still need to mark it but I have to cut some away under the 24-pin connector for the cable.
I sleeved the 24-pin cable and 8-pin cable.
The heatshrink isn't great so I may redo that.
Then I did some cable managment with some P-Clips
And the rainy season is back here in the Congo! We get some decent sunsets because of the weather.
Now for some more pratice shots.
And the best molex pin remover ever!!!
Sorry for all the photos but the only way to get better is to practice!
Fuga
PostPosted: Mon Oct 15, 2012 1:17 am
Here is another big update for y'all!
Finally got my paint and 3M glue in!
2 types of gold. I will ony be using the Rust-Oleum one though.
And the glue.
I also got in the Bitspower Dual Pump Top
I had to take one of the Acrylic layers off the bottom so the pump top would fit under the 240mm rad in the bays.
Put the pumps on with the Bitspower Mod Kit.
50mm fan grill. Not sure if I will use this or not.
Some fan cables. 1 for each rad.
EK Uni Brackets for the Res (These are so I can mount the res to the 5.25" bays)
And some thermal cleaner so I can get some nice clean chips.
Now for the modding!
I decided to venture in to heatshrinkless cables for the ones you can see at least. Here is my journey.
All the sleeve ready to go.
You have to have the sleeve almost touch the 2 prongs on the ATX pin.
I put some electrical tape on between 1/4" and 1/8" away from the end of the sleeve to keep the sleeving tight and to use as a guide.
Next you use a soldering iron to melt the sleeve to the ATX pin. Don't melt more that what is marked. (Obv the tape is in the way)
Now all you have to do is melt it just a bit more to make it cone shaped basically to fit into the connector.
And here it is all done.
Here is how my 24-pin cable came out.
And the 8-pin
I cut the holes for the fans in the mid plate and a cut-out for the 24-pin cable.
I made this photo so I could figure out which leather I would use for the midplate. I decided on the top one.
Here is how I was originally going to have the cables for the GPUs
But since I'm going heatshrinkless I can't do that so I did this instead.
2 of the cables were straight 6-pin cables but the other 2 were made for 1 GPU each so I had to cut off the extra link.
Now for a sweet mod!
Coming apart...
Presto Chango!!
Did the same thing to the MOFSET block.
Then I painted the SB heatsink.
Looks good!
And then the 50mm fan.
Now that all really ads some pop to the motherboard.
Since I decided to use the darker leather on the doors and here is what the first one looks like.
I also painted the mesh for the bottom gold too. Will be installed in the next update.
That's it for this update.
I'm working on the pump placement and routing to get the water from the res to the pumps effectively. Might need to do some fancy piping under the midplate with extensions and angled adapters... Hopefully some more gear will arrive this week so I can keep moving!
Fuga
PostPosted: Mon Oct 15, 2012 1:18 am
Happy to say that EK is sponsoring my build!!
Gregor was able to send me a few things. EK-Multioption 250 Basic Res, 8x 90 Degree rotary fittings and a T-Shirt.
Now for the update. It is kinda big because I have not had time to write it up so here goes.
I had to figure out a way to get the water from the res into the dual pump top. A direct run would not work so here is what I had to fashion out of fittings I had laying around. Kinda ugly but it works and its out of sight.
Got out my Curcial M4 128GB SSD and installed it on the Silverstone bay.
Found a 320GB HDD so I'll put that on there for now. I'm trying to get a 512GB SSD for games.
Now to figure out how to wire them all and make it look good...
I also cut the Slim ODD cable so only the power cable is left. I have to use a longer SATA cable than what came with it.
The 3-cable and 4-cable clips came in.
Added a bunch of them to the PCI-E cables and they look pretty good.
I finally got all the holes cut in the midplate so I put the leather on it.
Then I used a furniture marker to color the edges since its fabric and the back of the leather is white.
I like it.
Now for a fun mod. Old GTX 560Ti backplates.
Traced
Cutting and drilling is boring so I skipped that part... and now we have... leather backplates!
And gold brackets
I also covered the SLI bridge with some leather.
Looking good IMO...
I put the res in and added some random fitting to see how it will all work.
I had to make some brackets for the midplate to keep it level. The 24-pin cable pulls it down a bit in the back. Pics later of how they are mounted. (Ya I forgot to take them...)
But here is how it looks from the front.
Top panel before...
And after!
Paint the mesh gold and it looks great!
Painted all the thumb screws gold.
And installed.
Random shot...
Vacuum tubes!!
Playing around with how they will be sitting. (Not sure of final setup yet)
Cut the leds off the bottom so they sit flat on the midplate. I'll drill a hole under them for the LED.
I cut some small pieces of acrylic to hold the LEDs under the mid plate.
PROBLEM! I bought Yellow single LEDs instead of Amber so they don't match!!
I put in a order yesterday for some Amber ones and resistors.
I think we need some lighting.
Using a fan bus to power the LEDs
I bought 2 of these new ones since I only have 1 of the above one. (They have to be the same since I'm OCD like that)
I'm not set on only having Amber lights so lets add some switches so I can have white too!
Start making cables.
Finished. (More pics of this later)
Finally the rainy season is here! (It rains every... single... day...)
That's it for now! I have some more stuff coming this week so next weekend I will be busy.
Cheers till then,
Fuga
PostPosted: Mon Oct 15, 2012 1:19 am
Now we are upto date!! Hope you all are enjoying the log.
I wanted something to put behind the 2nd PSU bracket that looked cool so I made a stand.
Drilled a hole and covered it with leather.
And added a vacuum tube. I drilled out the bottom so I can put several LEDs in it to make it super bright.
Next up was to mod the EK-Multioption Basic 250 Res. I actually got some of this idea from B Negative.
Cut some leather.
And tested how it looked. Hmm needs something
Got a piece of aluminium.
Cut it and filed the edges
Painted it gold and cut a slot in the leather.
Taped off the res
Pained the end caps gold too
Put it all together and what do you get??
Not to toot my own horn but it looks freaking awesome. There will be 2 LED stop fittings in the top to illuminate the water inside.
Minor thing but I need move the top clamp up...
Thanks it! I changed up some things in an old build to get some more fittings for this one. I'll hopefully have some pipe next week so I can get the water going. Also my laser cut parts should be here the end of next week!
Fuga
PostPosted: Wed Oct 17, 2012 2:31 am
Little bit of work this week.
Got a package from Nils
I've been asked by several people for a pic of the whole case. Here it is.
I forgot to post a pic of the back of the mobo panel with the cabling and mid plate supports.
I installed the PSU and connected all the wires. Here is what it looks like.
I put the back side panel on to see how it looks.
I may make something to hide the PSU...
I put the 240 rad back in the case and ran all the wires to the FC10. Still need to zip some of the wires together.
I learned that I can connect a Bitspower thermal probe stopp fitting to my FC10 so I did. I used one of the open ports on the EX360 Multiport rad.
And I decided the fan in the roof of the case needed painted.
Looks better now.
Still more to do. Some of my packages were delayed so I might need another 2 weeks to finish this.
Fuga
PostPosted: Tue Oct 23, 2012 1:08 am
Things have been pretty busy for me so sorry for the delayed update. I try to do at least one update a week but sometimes that doesn't happen. Lately, Photobucket won't let me upload from home. Probably because of my shotty internet. Oh well, On with the modding!
I got a few things in the mail.
Gorilla Glue (This actually didn't work so I picked up a different kind)
You all wanted it so here it is. Copper tubing and a bender.
Another bender which I need to mod to accept the 12mm tubing and a cutter. The cutter is for hard tubing so I have to be careful when cutting the copper.
Modders Mesh
LEDs and LED strip
Acrylic order from Thomas at White Light Laser. He threw in tons of extra gears and stuff at no extra cost :D
Maybe for a future military mod?
These grills are for the vets on the doors. I painted them gold.
And glued them on. Pics later once they are dry.
I got my dual channel EK-RAM Dominator block so I painted it gold.
Random side panel shot
Added some foam under the pumps.
Got the FC10 installed and the DVD drive
I then made my own power cables for the DVD drive and 4x HDD/SSDs. Sleeved it and make it look as pretty as I could.
I need to cut some holes in the mobo tray for all the cables. I'm still filing but here are the marks.
Now to make the custom front panel.
All cut
Epic fail. I used too big of a hole saw...
Remade!
Perfect fit.
Trimmed off the wings. I was going to fold them in but it would have been more work.
The big hole in the middle will be covered with gold mesh just like the side panels. The entire front panel will be coverd by leather to match the doors.
The big hole looks a bit crooked... After getting out the square, it is. I'll be cutting/filing that soon.
Cut and filed the DVD slot
Drilled all the holes for the FC LEDs to show through
So those LEDs I ordered... look freaking orange again! They say amber though. I ordered some more from a different place, well same place I got the LED strips from so hopefully they will match. They are from Hong Kong though so shipping takes like 2 weeks.
So out of the acrylic parts there were 2 big gears. Here is where they go.
Paint them gold.
They looks good. Also you can see a small gear around the fill port.
I also had gears made for the power buttons.
Thats it for this update. My to do list is getting shorter every day but I keep adding one or 2 things a day... but thats modding for you. Only things I'm waiting on is the fittings for the tubing and new LEDs.
Fuga
PostPosted: Mon Oct 29, 2012 12:34 pm
Been working hard to get everything done.
Here is the glue I ended up using. it works great.
Got my Bitspower Multi-Link adapters in.
Bit of bad news... FC10 broke. I think it broke when I way trying to push it into the 5.25" bays. its a tight fit and my finger slipped and hit one of the vacuum tubes. Lamptron is sending me 2 new ones :D
I started the piping. Left pipe is from the pump top outlet to the 240 rad. Right pipe is from the 240 rad to the 480 rad.
Right side has a small dent. I may replace this pipe but you can't see it with the front panel on.
First connection on the mobo.
2nd
3rd & 4th
Inside the case with the 5th tube
Last tube from the GPU to the res
More fittings came in!
Here is the grill for the 50 mm fan
Drain port. there is a T line between the 360 and 480 radiator.
LEDs on
Now for the front panel. I used JB Weld to hold it in place.
BAH! A gap...
Add more JB Weld
And then sand the hell out of it.
Now that that is done I need to add the leather and grill. I like it!
I picked up some old gauges. Not sure if I am even going to use them but they were $10...
Testing...
Add some tubes
I threw a blue LED in the res to see what it would look like.
Underexposed
No idea how to hide these cables from the front I/O ports...
My fill port :D
And finally I flushed all the blocks to make sure no crud was in there.
More to come soon. I got my LEDs in today so I'm going to start working on that ASAP.
Fuga
PostPosted: Thu Nov 01, 2012 4:57 am
Not a huge modding update but I got a bit of cool gear in.
I got a Technofront water cooling test bench and 2x new Koolance flow meter displays. Can't wait to use em!
And its Halloween so the family and I did a bit of pumpkin, I mean gourd carving.
She was very interested... made it kinda hard to carve lol.
All done!
Now not to brag, but my wife makes some damn good looking cookies.
Now for the real work... I painted the PSU fan.
Here is a picture of the broken FC10 nixie tube.
Now remember that huge vacuum tube I made with a bracket? Well I got the Amber LEDs in and its time to light it up.
Here is what all the cables look like coming from the front I/O panel.
And just some lighting shots.
Fuga
PostPosted: Fri Nov 09, 2012 11:41 pm
So after years of work I finally made it into the Bit-Tech MOTM! Its been a dream of mine since 2006 to be in the MOTM competition. If my like my project and have an account there, please go vote! http://forums.bit-tech.net/showthread.php?t=248935
PostPosted: Mon Nov 12, 2012 10:59 am
Absolutely amazing!
PostPosted: Mon Nov 12, 2012 3:05 pm
Stunning! Simply stunning!! This isn't a mod, it's a work of art.
PostPosted: Mon Nov 12, 2012 10:21 pm
Thanks guys!
