It is currently Tue May 21, 2013 9:51 pm
 Post subject: Boot Error
PostPosted: Sun Oct 14, 2012 8:35 am
I can not logg on to Windows...I get the error System32\Drivers\pci.sys is missing or corrupt. I have run : bootrec.exe /fixmbr
bootrec.exe /fixboot
bootrec.exe /RebuildBcd
From the command prompte. but the RebuildBcd did not work (although it states it was completed successfully).
Does ANYONE have a LINK or a solution to this problem. I do not have a back up disk for this computer or a restore point.
 Post subject: Re: Boot Error
PostPosted: Sun Oct 14, 2012 8:51 am
Should have indicated Windows7...sorry. If any more info is needed please let me know. or even point me to another site that maybe able to help.
PostPosted: Sun Oct 14, 2012 11:56 am
Have you tried a repair install?
EDIT: Actually I'm not sure if this is even available anymore... I think they replaced this with the "Fix startup problems" or something.
