It is currently Wed May 22, 2013 10:03 am
 Post subject: Horrible LAG while playing LAN games
PostPosted: Mon Oct 08, 2012 10:19 am
Hey guys.. I'm having an issue with LAG while playing games through LAN. Right now the problem is Borderlands 2.
I host the game on my PC..
I5-2500K @ 4.5
Gigabyte Z68X-UD4-B3
Corsair Vengeance 8GB DDR3 1600
XFX 6950 XXX 1GB @ 1000 / 1500
AData 64GB SSD; 2x WD Black 750GB RAID 0
Win7 Pro 64
Can't think of the Brand / Model of the network card but it is a dual antenna Wireless N.
My sons pc is:
Athlon X3 720
Gigabyte GA-MA785G-US2H
Kingston HyperX 4GB DDR2 1066
BFG 9800GT HDMI
Linksys WUSB54GSC-4A (Wireless G)
The router is Cisco-Linksys WRT160N-RM Wireless-N Router with DD-WRT.
When he connects to my game the lag is unbearable. He constantly freezes and there is at least a one second delay when jumping, firing, etc.. I did order a Wireless N adapter just in case it could be that, although I would think G would be enough.. maybe I'm wrong. Think it's the adapter or could it be something else?
 Post subject: Re: Horrible LAG while playing LAN games
PostPosted: Mon Oct 08, 2012 12:57 pm
Did you try pinging from his computer to another device on the network? If his pings are normal, it just isolates it to the game.
PostPosted: Mon Oct 08, 2012 12:59 pm
I didn't try pinging but I will tonight. It happened with Borderlands one as well but those are the only two games we had attempted.
PostPosted: Tue Oct 09, 2012 5:34 am
If his computer isn't powerful enough to host a lan game, that will cause lag as well.
PostPosted: Wed Oct 10, 2012 5:24 am
I host the games with my PC. Either PC should be powerful enough to host though.
I tried pinging and I have excellent response times, 2-3ms.
PostPosted: Wed Oct 10, 2012 5:26 am
Is everyone fully patched?
PostPosted: Wed Oct 10, 2012 7:54 am
Yes we are. I have two Steam accounts so we can co-op together.
PostPosted: Wed Oct 10, 2012 8:37 am
Your sons video card is out of date for that game, have him dial out all the eye candy, go down in resolution to 1024X768 and try it again.
PostPosted: Wed Oct 10, 2012 9:11 am
Already done that. 1024x768 is his monitors resolution and he can play it without issue at low - medium settings. I'm scratching my head on this one lol.
PostPosted: Wed Oct 10, 2012 10:46 am
Are you connecting WiFi or Cat5e? If Wifi, try a crossover cable.
Are you connecting the two computers together using Cat5e? You should be using a Crossover cable in this case unless your nics support crossover already and can use just Cat5e.
PostPosted: Wed Oct 10, 2012 10:51 am
Wireless and I'm not connecting directly to the pc, both PC's are connected to the router.
PostPosted: Wed Oct 10, 2012 11:47 am
Do you have sharing setup?
Do you have the proper ports open for the game, you may have to go to the game site to find out which ports to open in the router.
PostPosted: Thu Oct 11, 2012 5:13 am
I have the ports for BL1 shared.. I would think it's the same for BL2 but I'll check on that.
PostPosted: Fri Oct 12, 2012 3:44 am
Changing the NIC fixed the issue. I guess Wireless G isn't enough bandwidth for the game.. dunno.
PostPosted: Fri Oct 12, 2012 4:05 am
....well, at least you found the issue and fixed it... :mrgreen:
PostPosted: Fri Oct 12, 2012 7:29 am
Yea.. honestly I didn't think it would be the card.. maybe it was a combination of the Wireless G and the fact it was an external usb adapter.
