It is currently Tue May 21, 2013 12:03 am
Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2
 Post subject: Re: HP - Boot Manager Screen
PostPosted: Mon Oct 01, 2012 6:34 pm
I followed the link. That didn't fix the issue.
PostPosted: Thu Oct 04, 2012 7:07 pm
I am throwing in the towel on this issue. I have tried everything I know. Idea's provided by others and nothing seems to work. It continues to load to the boot manager screen and shows one OS. If I reboot the machine with anything attached to the USB ports or in the CD drive it just beeps till you hit a key on the keyboard. I have changed the boot order, I have done the "msconfig" - "boot", I have done clean install with orignal OEM HP disks. I changed the hard drive and did a complete re-install again. Tried EasyBDC. Removed the CMOS battery, Laptop Battery and left it unplugged for hours. Reseated the memory chips, CD/DVD drive, Keyboard connections and any other connector visible without completely removing the motherboard. Upgraded to the latest BIO's from HP
HP Pavilion dv4-2045dx
Winows 7 Home Premium - 64bit
4GB Ram
320GB WD Black
