It is currently Fri May 24, 2013 8:08 pm
 Post subject: iPhone 4(S): Need iTunes-Like Software For Windows 7...?
PostPosted: Tue Aug 28, 2012 3:34 pm
I feel so dirty, having to use an iPhone, but it was the only phone that I could get for $0, I am an Android user, but couldn't afford to buy any phone outright...so I am stuck with this dirty phone instead.
Now that I've got that over with.
Is there any application that is iTunes like that I can use to add MP3s and/or videos to the iPhone?
 Post subject: Re: iPhone 4(S): Need iTunes-Like Software For Windows 7...?
PostPosted: Tue Aug 28, 2012 4:01 pm
Apple hardware working on non Apple software. Good luck.
You could try Winamp, it had iPod support (which may or may not be the same thing) last time I checked. Or http://www.makeuseof.com/tag/6-ways-to- ... ut-itunes/
However if you need access to the App Store or something else beyond iPod functionality, you're out of luck.
PostPosted: Thu Aug 30, 2012 10:04 am
You're funny! You do realize you've bought into the AppleEcosystem, right? You're stuck with whatever the AppStore feeds you. Safe to say, Cupertino will never allow anything remotely iTunes like. If you are serious, jailbreak it.
PostPosted: Sat Sep 01, 2012 5:09 am
Well, less than 24hrs after getting an iPhone after posting my original question on the 28th of August, WirelessWave at the CNE got a shipment of Samsung Galaxy Nexus phones, and I got one -- I would've preferred a GSIII -- but now I am clean again, no more Apple product.
PostPosted: Tue Sep 04, 2012 5:25 am
Great escape! Keep your head up high!
