| Coppermine |
I can get onto this website just fine. Go through page by page but when I go to add my reply, I get the below message:
"The page you are trying to access is restricted due to a security rule.
If you believe the security rule is affecting the normal operation of your website, you can disable it by adding the following lines to your .htaccess file:
<IfModule mod_security.c> # Turn the filtering engine On or Off SecFilterEngine Off </IfModule>"
Can anyone help with this or explain why it is coming up? Thanks.
