It is currently Thu May 23, 2013 7:59 pm
 Post subject: Router / Range Extender issues
PostPosted: Thu Jul 19, 2012 7:24 am
This is something I should be able to figure out but for some reason having an issue. I have two routers and this is the setup:
192.168.1.1 - WNDR3700 (MAIN ROUTER
192.168.1.2 - WNDR3400 (RANGE EXTENDER)
Extender using same SSID, Encryption type and password. Tried same channel and also Different Channels 1 and 6
Removed the extender from DHCP and set for repeating function.
My issue is this. The second I press save on the 3400 and remove it from DHCP I no longer have access to the router. I can't get any connection, can't ping, nothing.
Any ideas? BTW tried this same setup on two different devices. As actual routers they work just fine no glitches-- perfect.
 Post subject: Re: Router / Range Extender issues
PostPosted: Fri Jul 20, 2012 3:25 am
Flipper,
Are both devices up to date as far as firmware goes? A firmware update usually "fixes" problems the users reported to them. It may fix this issue.
PostPosted: Fri Jul 20, 2012 4:39 am
yes they are both up to date. I think I figured it out. I had to set my local machine to a static IP.
