It is currently Sat May 25, 2013 11:08 am
 Post subject: have a video card issue question
PostPosted: Sun Jul 15, 2012 4:47 am
i have windows 7 64 bit home premium and nvidia based gtx 560 ti yesterday my graphic drivers quit 3 times .. is that normal? yeah they recovered after a few seconds but my screen went black for a few? my drivers are up to date i checked on nvidias web site .. what can i do?is it normal?
 Post subject: Re: have a video card issue question
PostPosted: Sun Jul 15, 2012 6:09 am
best thing to do is completely uninstall the drivers and reinstall. turn off all antivirus. with a good clean install, if it still does it, then it may be a weak power supply or to many things on one rail (depends on the psu) if it has a single 12v rail or several rails.
500w min, and 30amps on the 12v.
PostPosted: Sun Jul 15, 2012 10:40 am
i have this system for a year and half i got i think 700 watts power supply and i did a clean install of the drivers
can it be my card is on the verge of dieying?
PostPosted: Sun Jul 15, 2012 9:21 pm
hard to tell, you could try a video benchmark that will stress it, and see if it still does it http://www.3dmark.com/
PostPosted: Tue Jul 17, 2012 7:35 am
ran the test and it said everything is running fine
