It is currently Sun May 19, 2013 10:46 pm
 Post subject: Any way to configure Hardware RAID1 without loosing data?
PostPosted: Fri Jul 13, 2012 4:39 pm
I want to switch my 2 (3TB) HDDs (non-bootable, just data) from Windows mirror to Hardware RAID 1. But I don't know if it will wipe out both drives in RAID building process, I'm ok if it erases one of them but I really don't have any place to copy all the data first :(
It's Marvell 9128 RAID (SATA3) on Gigabyte X58a-UD3R (Rev. 1) motherboard.
From the manual it's not entirely clear if not enabling "Quick Init" will not erase all data.
BTW reason I don't want to use Windows software RAID is when I have computer crash mirror get's broken and starts to resync which with 3 TB drives takes about a day! That's a good way to wear our the drive :(
 Post subject: Re: Any way to configure Hardware RAID1 without loosing data
PostPosted: Fri Jul 13, 2012 9:30 pm
it will erase everything.
PostPosted: Sun Jul 15, 2012 4:47 am
Yup, It will erase everything during the process of building the raid 1 array in the bios. It will warn you first before it kills everything on the drives.
Mirrored raid and raid 1 both work the same, and yes, it will take a day to rebuild a drive in raid 1 also....and no it is not going to kill your drive to do so.
PostPosted: Sun Jul 15, 2012 4:56 am
Copy everything you need over to another hdd, internal or external...it makes no difference. Then reconstruct your Raid 1 and and put everything back where you want it.
PostPosted: Sun Jul 15, 2012 6:25 am
That statement pretty much says it all kleinkinstein.
He simply cannot do what he wants to do with the resources he has.
PostPosted: Fri Aug 03, 2012 10:47 am
Actually I eventually found room on another HDD to copy all of it (and deleted lost of old crap in the process). All of you were right it did erase everything, thanks! :) I'm so much happier now with hardware RAID.
